Question about HTC G1 Smartphone
My adp1 is stuck on bootloader screen has RUNNBH in the upper right hand of boot screen and when i try to install a new ,nbh file it fails every time...help please
  • brookenewbyf Jul 09, 2010
    I HAVE AN HTC ADP1... I TRIED TO FLASH AN UPDATED RADI IMG AND ENDED UP FLASHING THE GOOGLE PHONE TO T-MOBILE'S STUFF....NOW ALL THE PHONE WILL DO IS OWER UP TO THE BOOTLOADER SCREEN... IT NEEDS THE DREAIMG.NBH FILE...I HAVE GONE THROUGH TABOUT TEN TRIES AND EACH TIME IT FAILS THE UPDATE AND TERMINATES. I AM CLUELESS ON THE STEPS TO COMMUNICATE WITH THE SDK/TERMINAL/COMMAND OPTION. SO I HAVE NO CHOICE BUT TO USE 5THE SD CARD IN A EXTERNAL READER AND FORMAT TO FAT32, COPY THE DREAIMG.NBH TO CARD, EJECT AND P-UT BACK IN P-HONE, POWER UP HOLDING THE CAMERA BUTTON AND I GET TO THE UPDATE SCREEN, PRESS THE POWER BUTTON TO START, AFTER ABOUT 5 MINUTES IT FAILS AND TERMINATES THE UPDATE SAYING FAILED....WHAT CAN I DO?
    THANKS FOR ANY HELP
    google dev phone 1 needs RUNNBH.... each file i try fails....help
  • 677 Answers
FREEZING OF PHONE
Hi, when a phone randomly freezes, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Posted on Jul 08, 2010
  • HTC Master
  • 6,993 Answers
your phone's system file is corrupt, that's why it cannot load. The system files needs to be reinstalled for the phone to come back to normal.
I would advice that you take the phone to a repairman and it will be flashed for you. Flashing a phone means formatting the phone and reinstalling new system files.
This is not a task you can perform yourself, because you do not have the facilities to carry out the flashing.
The situation is exactly the same as a corrupt compute operating system where the operating system will have to be reinstalled.
I hope you understand this.
Good luck.
Posted on Jul 09, 2010
    I thought thats why i got a developer phone.. so i can do this when something goes wrong...i have no repair person available as this is a dev phone carrier free....
  • Walesarumi
    Walesarumi Jul 09, 2010
    The other option you have is to install the firmware update. This should repair the corrupt files.
    Download the software from this link: http://www.g1-news.com/2009/06/02/how-to...
    Then learn how to install the firmware using your computer and HTC cord from this link: http://www.htc.com/uk/SupportViewNews.as...
    I hope this helps to solve your problem.
On a Dell optiplex gxa, running lenux after my son tried to transfer a hard drive from a hp running windows 8, I cant get out od a boot loop. Is there some way to get it to boot
Try the linux install again. Don't format, and it should hang on to all your files. If you have important files that you haven't backed up, you might want to search for a linux repair distribution. I'm usually hacking someone's lost password, which is a different war. If your bootloader, is trashed, a reinstall should fix. Windows loves trashing boot records, so I'd avoid letting windows anywhere near the system. you don't mention which bootloader you use, so search for repair bootloader + the name of the bootloader or the name of the distribution, like grub or lilo for the bootloader or ubuntu or mint, etc.
Dec 09, 2014 | Computers & Internet
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
Im Yasein From Egypt i have HTC TOUCH P3450 Mobile written back movistar Mobile and the Spanish language and I want Windows or English Arabyalmobail works with Windows 6 Professional and I wish you any...
hi yasein, what version of windows is on your pc?
download these two files and extract both
this one is the spl installer which needs to be run on your computer, if you get an error you will need to use the next download on the phone first
http://www.mediafire.com/download.php?sspbx0b1o3dqmtl
this next one needs to be extracted and then copied to your phone and then opened on the phone itself to be installed
http://www.mediafire.com/download.php?dvubl37qzaw2mh0
Please make sure Activesync is enabled (green icon in systray)
and hit ENTER to start...
STEP 1/3......50.......75.....100.
The next step will load a patched bootloader (SPL) on your device
it will make your device temporary SuperCID (seclevel=0), and will
avoid modelID and signature checking when flashing NBH files.
Hit ENTER to continue...
STEP 2/3.....15......25....50....75......100.
Phone screen should now be blank and the activesync icon gray
if not, the loading procedure has failed and you'll have to repeat again.
If all was OK hit ENTER and the standard "PDA Phone ROM Update Utility"
window will start, allowing you to flash patched SPL on your device.
Hit CTRL+C to Cancel or ENTER to continue...
Follow the steps on the wizard to flash the patched SPL, when this
step completes your device will reboot.
STEP 3/3 - Launching RUU, please wait...
Process is finished, congratulations!
If you find it useful don't forget to donate :)
(c)2007 pof - XDA Developers
Hit ENTER to quit.
Hit ENTER to quit.
then follow these instructions
STEP 1/3......50......75....100
STEP 2/3.....15......25....50...75.....100
Hit ENTER to quit.
if you have had success with installing the first file and it has completed without error then you can now download this file
http://andrewloh.com/HTC/New_Blue_Touch_ROM_V4.0.zip
extract all files in it and run the ruu_setup file in there and follow
th instructions on screen. When its finished you will have wm6.1 in
english installed on your phone
May 01, 2011 | HTC Touch P3450 Smartphone
OXCOOOOOOF I was doing disk partition
Grab a copy of :
EasyBCD is NeoSmart Technologies' multiple award-winning answer to taking control of your bootloader. EasyBCD extends and revamps the Windows Vista/Windows 7 BCD bootloader, and with EasyBCD, almost anything is possible. Setting up and configuring a dual-boot between Windows 7, Windows Vista, older versions of Windows such as XP & 2003, Linux, Ubuntu, BSD, and Mac OS X is a breeze. You just point & click and EasyBCD does the rest.
EasyBCD is geared for users of all kinds. Whether you just want to add an entry to your old XP partition or want to create a duplicate for testing purposes; if you're interested in debugging the Windows Kernel or septuple-booting your seven test operating systems, EasyBCD is the key.
  • Boot into XP/Vista/7/Ubuntu/OS X and more!
and if :
Your "BOOT" folder has been deleted, was not created, or has been corrupted; and the Vista bootloader will not show.
Solution Boot into a working copy of Windows and install/run EasyBCD.
Go to the "BCD Backup/Repair" page:
Select "Re-create/repair boot files" then "Perform Action" to begin recovery. EasyBCD will recreate (if possible) your boot files and re-configure your bootloader from scratch.
If EasyBCD fails, that means a process has locked your BOOT folder. Manually delete this folder with a Live CD, recovery console, or other method, then try Type Three again.
Dec 11, 2010 | Toshiba Satellite P205-S6287 Notebook PC
HTC Dream "G1", locks on the boot "T-Mobile G1" screen. Will not hard reset or fast boot.
The phone needs to be reprogrammed / reflashed with the original software.
you need to obtain a rom image of the phones program and then place it on a storage card that fits to the phone.
Then you need to start the phone in boot loader mode to flash the program.
you can also try the recovery mode and see if allows you to fix the issue. more information about programming the phone here http://wiki.xda-developers.com/phpwiki213/index.php?pagename=HTC_Dream_overview_and_useful_information
if you require a rom file for the phone you may be able to find one from http://forum.xda-developers.com/wiki/index.php?title=HTC_Dream
if you are unable to get the phone to function contact your dealer or take it to a repairer.
recovery mode Hold Home button and press power button In this mode you can open shell/flash image/perform backup etc. depending on which recovery image you have on the phone. Press CALL+MENU+POWER buttons simultaneously to exit mode.
bootloader mode Hold Camera button and press power button In this mode you can install new system image (DREAIMG.NBH) from SD card by just pressing power button again.
Sep 13, 2010 | HTC G1 Smartphone
My phone jus shut off by itself n now it wont turn on. everytime i push the power buton a blue light comes on but the phone doesnt
its odd that it's a blue light, its usually red. if i were you i would try reflashing the firmware. try turning it on in bootloader mode (hold the camera button while powering on it should boot into a rainbow screen ) if that doesnt work then youre screwed, if it does, then you need to find a way to get an official update.zip file or dreaimg.nbh onto the base of your sd card (not in a folder) if you use dreaimg.nbh it will downgrade to the very first release of android, and should update within a couple of days, or you can read up on how to flash firmware and find official updates to download just look on google, theyre all over the place.
Jan 12, 2010 | HTC G1
Dreaimg.nbh fail
Okay here is your problem. The file is case sensitive, so whenever I flash the nbh file, I have it renamed to DREAIMG.nbh. I am pretty sure that DreaIMG.nbh will work also, but I use all caps except for the .nbh. Also give a double check and make sure you are seeing the actual filename without a hidden extension there.
Make sure that you're pressing the camera button on the lower left side when you power up, not the volume down for this one. Then just follow the screen, quite fast...
Oh have you messed with the file already at all? If yes, download a new nbh as that one can be messed.
EJ
Aug 22, 2009 | HTC G1 Smartphone
V3a stuck on bootloader usb init screen'
flash your phone thru RSDlite and it be ok.
download rsdlite here:1.http://www.motorolafans.com/forums/a1200-applications/13457-rsdlite-download-here.html
download firmware here:2.http://rapidshare.com/files/62231936/MPC_V3A_01.1F.01R_PRInn22217_MONSTER_01.rar.html
after download complete install rsdlite to your computer.run rsdlite and plug your phone while in bootloader mode.if phone ask a driver,go to program files,rsdlite,p2k driver.after installing driver,flash your phone...
Jul 19, 2009 | Motorola Mobility RAZR V3a Cellular Phone
AFTER FLASHING MOBILE DEAD POWER IS`NT ON.
It sounds like you've had problems writing a custom ROM to your phone. You have done it correctly using the CID unlock. Are you using the same WM6 ROM that you have done before?
Firstly, turn off your XDA Orbit.
Then hold down the voice recorder button on the left side of the phone
Then press and hold the power button on the right side of the phone, whilst still holding the voice button on the left.
This should get you into "bootloader mode" which will display a screen with red, green, blue and white stripes - yu should now be able to instlal your ROM using the RRU from the computer with USB connection
If that is not possible, you can install the ROM from a microSD card if you first format the card into Fat32 file system from your computer, then copy the NBH file from your ROM to the microSD card. You will need to rename the NBH file from the ROM to ARTEIMG.NBH for this to work.
Enter bootloader mode and you should see a prompt to press the volume button downwards to start the ROM installation process.
See this page for more information on the MicroSD ROM installation:
http://wiki.xda-developers.com/index.php?pagename=Artemis_SD_Card_Flashing
Nov 09, 2008 | O2 Xda Orbit Smartphone
Upgrade Problem
i am unble to install dictionary in htc 3400.
Feb 23, 2008 | HTC Touch P3450 Smartphone
HTC G1 Smartphone Logo
127 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
