Question about Dell Latitude D600 Notebook
Cannot open c drive using double click. - Dell Latitude D600 Notebook
    President:
  • 2,571 Answers
Try right click on my computer/manage/disc managment then right click on c drive and explore.
this works for usb drives that have a drive letter conflict also
Posted on Jul 09, 2010
  • Roy
    Roy Jul 10, 2010
    If double clicking c drive will not work, then there is an underlying system problem.
    Without physically being in front of your pc the easiest way to access the missing or problem drive is to access it from Disc managment.
    Problems opening your C drive is usually a sign that the drive is about to fail.
    Double clicking my computer and getting the egg timer is another sure sign of a faulty Main hard drive.
    Back up everything you cant do without and replace it asap
    1 thumb was a little mean
  • Roy
    Roy Jul 10, 2010
    If the advice i gave was not of any help could you please leave more information so i can understand your problem in more detail.
    The problem as i understand it does sugest a hard drive that is failing.
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Tip
Drive not open on 'double-click'
Open 'Notepad' and write following code.
[autorun]
open=C:\Windows\explorer.exe
Save file as 'autorun.inf'.
Copy/replace this file on all drives/partitions that are not opening on double-click.
Restart PC and now all drives should open with normal double-click.
on Aug 26, 2010 | Computers & Internet
How I can open this external hard drive
Window:
1. Connect the drive to your computer
2. Go to My Computer
3. Double-click the external drive (it should be listed under "Devices with Removable Storage")
4. Explore and use your hard drive
Mac:
2. Double-click the external drive (it should be on your desktop)
3. Explore and use your hard drive
Hope this helps!
Mar 19, 2011 | Hitachi Computers & Internet
Kingston 2GB pen drive not opening by double click
This is cause by a virus or something , first thing that you can do here is to back up all the files from your pen drive and then one everything is already back up you can go ahead and format the drive, just right click the pen drive and select format....that should;d fix the problem,,,,
Dec 28, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
D,f drives "access is denied" on double click. but opens when rt clk and 'open'
What OS you're using?
Are you having Admin rights on the system you're trying to access the e&f drives?
If you have admin rights, then try to look at the security options of the drive (Right click on the drive and check properties). Make sure that your login name / your group is listed with full permissions.
Oct 26, 2008 | Microsoft Windows XP Home Edition
Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini).
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
Microsoftpowerpoint.exe
smss.exe
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
May 31, 2008 | Microsoft Windows XP Professional With...
Cannot open my D drive by double clicking but it shows the option open with note pad help
You drive has been infected by a virus. but I think you can still open it by not double click rather to right click on the D drive and choose explore from the menu.
But this not the solution save the files somewhere and work out on removing the virus.
Mar 27, 2008 | Computers & Internet
Hard Disk drives are not opening on Double click?
del c:\autorun.* /f /s /q /a
use this command in other drives also before that use task mangar and endpprocees explorer.exe then use new task for command promt" CMD"
Dec 11, 2007 | Compaq NX6110 TFT XGA Notebook
When i double click on the drive autorun error
Reformat your drive. try to use FAT32 to perform the reformat and create partion.
Aug 29, 2007 | Microsoft Windows XP Professional With...
Dell Latitude D600 Notebook Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
