Question about Garden
Hello i need a new impeller for a waterwerks pond pump. Model number ww3505.
2 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: Laguna 7000 pond pumps stopped pumping
No, once this inside of the cylinder cavity is scored it's toast, the only hope is that it is still under warranty.
Posted on Feb 05, 2009
I have a brand new hozelock easyclear 6000 pond pump. When I plugged it in.....nothing!. Outdoor electrical socket working ok. The pond is newly built so their are no leaves or sludge in the pond, in-fact...
Sorry to hear of your setback but hopefully we can get you back to worrying about your pond occupants rather than the equipment. First remove the filter cover and filter and give the impeller a gentle turn to feel if the bearing or motor is jammed. If it turns freely try powering the unit to check if the impeller turns, sometimes the impeller needs a little bump to get it moving at first. If nothing still happens return the pump for a replacement.
Mar 28, 2011 | Imperial Garden Products OSI Submersible...
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Pondmaster mdl 24 Series magnetic pump. re: Replacement impeller/magnetic shaft installation Question: What do I need to do to install the impeller ***'y into the pump housing to ALLIGN THE...
The bearing needs to be pressed onto the ceramic shaft before inserting the impeller into the housing. Then it just drops in (while trying to hold on to it the best you can to keep it from slamming in.). New bearings didn't come with the new impeller? If not you will have to carefully pry out the old bearing from inside the housing.
Aug 18, 2010 | Pondmaster Impeller & Magnet for Pond -...
Have a 10 year old salt water pool with a PH1 Dura-Glas pump which is now not pumping enough water. Have recently fitted new filter etc. Does the pump head wear on this model and if so where do I...
If you had a crack in your basket then you may have a plugged impeller. You can reach the center of the impeller with a screwdriver and needle nose plier from the hole inside the pump pot.
If not you may have a problem with your impeller or the small "O" ring on the difuser. For this you will need to take the pump apart at the band clamp. Good luck.
Jan 31, 2010 | Water Warehouse Nsf Approved Sta - Rite...
Does anyone know where I can get a replacment impeller for a 2008 model Sunterra 2000 gph pump ? The cover comes off and looks replaceable. I have a warranty replacment 2009 model and the cover of it is...
If you find a replacement 2000 Impeller for your 2008 sunterra pump, let me know! I called the company who promptly told me they don't sell component parts for any of their pumps larger than 1250. They very matter-of-factly told me to go buy a new pump.
plasticmaster@msn.com
Oct 29, 2009 | Sunterra 202000 Pond Pump 2000 Gph, Black
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
My pondmaster pump model 18 will not start back up
Usually when those pumps start doing that the impeller needs to be cleaned. Just remove the impeller housing with a phillips screwdriver and carefully pull out the impeller. I use an aquarium tubing brush to clean the impeller. A bottle brush will work too. Be very careful when you re- insert the impeller back into the housing, as the strong magnetic force will slam it back in if you aren't holding on to it with a good grip. Try to avoid that.
It's also possible that the impeller is going bad and needs replaced (probably about $40 for that pump). Sometimes the bushings wear out too.
Check inside the motor housing for scoring, not good. The only cure for scoring is to replace the pump.
I
Jul 09, 2009 | Garden
New pump not pumping
I can only imagine that something has jammed the magnet/impeller. take the screws off the volute and remove. Pull out the impeller assembly and inspect for possible source in magnet chamber and impeller housing. That is a very problem free model.
Mar 15, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Nov 21, 2008 | Garden
Execetive 56 4hp pump
Looking at the face of the pump, the impeller unscrews by turning it counterclockwise. Also, for some strange reason, the 4HP pump gets a 3HP impeller; the rating is embossed, in very small letters, near the center of the impeller. The 3HP impeller part number is: 310-4200.
Be sure to change the seal: US Seal P/n: PS-1000.
Oct 20, 2008 | Waterway Spa Pump Executive 56 Frame 4hp...
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
