Question about Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
On my Roper Dryer, the heat won’t come all the time.
At first it was in the automatic sensor dry setting and then went to all the settings.
Today I tried it again and it works great full heat in all settings. Timer maybe?
  • 943 Answers
Hi first thing to do is clean all the venting and try again. thanks the appliance doc
Posted on Oct 16, 2008
SOURCE:
Roper model red4640yq1 heats in auto mode but not on timed dry
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Feb 26, 2016 | Roper Dryers
My roper gas dryer seems to be getting heat (not very hot) but isn't drying clothes. the selector nob only turns under timed dry.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 23, 2011 | Roper RGX4634KQ Gas Dryer
Does not heat, automatic timer when out first
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 17, 2010 | Kenmore Dryers
No heat
heatman101
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes not dry but dryer turning. cleaned out
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
Hi i have a roper electric dryer and it will go threw all the cycles but wont dry clothes like wont heat up
heatman101
Jul 05, 2010 | Roper REX3614KW Electric Dryer
Dryer Spins but clothes dont dry
heatman101
May 22, 2010 | Roper RES7646KQ Electric Dryer
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
No heat during either drying cycle automatic
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
Roper RGX4634KQ Gas Dryer Logo
199 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
