Question about Lincoln Pro Cut 55
The reset will not work
The plasma will not reset. I have a safety fault. have tried new tips. turning on and off. checked the air. any help[ would be appreciated.
2 Suggested Answers
  • 73 Answers
SOURCE: pro cut 25 plasma cutter : turn it on and get a
yes you need to find and fix the leak, it will show fault if not enough air pressure is there, double check airline connection exterior, and then airline interior after regulator valve also check for are around the regulator,
hope this helps.
Posted on Feb 03, 2010
Testimonial: "thank you very much this is a very big help for me have a great night jon"
How to diagnose television fault?
diagnose television fault Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1491814-common-diy-diagnosis-repair-info-plasma-led-lcd-ccfl-lcd-tv-sets-monitors-display-devices-mostly-power-supply-repairs.html
How to Diagnose TV Problems
http://www.repairfaq.org/samnew/tvfaq.htm
Latest Repair Tips
Apr 16, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I purchased a I60 Plasma cutter and I don't have an instructions manual. Can I download one?
Plasma Cutting Guide - Plasma Cutter Tips - The Eastwood ...
www.eastwood.com/plasma-cutting-guide-plasma-cutter-tips-plasma-cutt...
Check out Plasma Cutting Guide at Eastwood tech library to know about ... hasapproximately 25 amps of output, a 1/2" machine has a 50-60-amp output, while ...When buying a plasma cutter, the manufacturer should provide cutting .... Finally, follow all safety tips and guidelines that are detailed in your instruction manual.
How To Select And Operate A Hand-Held Plasma Cutter ...
https://www.millerwelds.com/.../how-to-select-and-operate-a-hand-held-...
The actual process of operating a hand-held air plasma cutter unit is relatively .... If you only have 115V primary service, don't worry. ... 50 or 60 Hz. This means you can plug this plasma cutter in anywhere in the world. ... If you opt to purchase such a unit, position it as far away from the particle ... Plasma Cutting Roller Guide.
Best Plasma Cutter Reviews 2015 - AIR TOOL GUY
Dec 27, 2015 | Welding Tools
Shuts on on safety ,,almost immediatley
Check that the tip is assembled correctly.If is not in properly, it will not arc. Second, check air pressure switch. Sometimes they become stuck from corrosion due to moisture in the air. Test the operation with a tester
Nov 01, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Pro cut 25 plasma cutter : turn it on and get a fault and hear air leaking from some place. will not cut just a safety fault
hope this helps.
Feb 03, 2010 | Lincoln Welding Tools
Safety light
check the gun lead all the way back to unit,if there is a nic or cut in that lead (main power lead)the unit will not fire,sadly you cannot fix the lead ,it has to be replace with new one,
Jun 06, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Nov 26, 2008 | Lincoln Pro Cut 55
Plasma cutter
in order to cut the thicker steel just boost the air pressure this will allow you to thourghly blow through the steel. just remember not to turn it up too much. this should do the trick. please rate
Sep 15, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Lincoln Pro Cut 55 Logo
47 people viewed this question
Top Lincoln Welding Tools Experts
joe2639
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
