Have a Janitrol Model CK36-1A air conditioner and outside unit does not turn on. Notice two low voltage wires are not connected. One white the other green. Where can I get a Manual and/or scematic to reattach and get working.
  • 532 Answers
After checking breakers, I would check Indoor unit float safety switch, sometimes installers use the float switch to shut all power to thermostat off and others shut down outside unit only.
If indoor unit is in closet or vertical in garage, look at bottom of unit where PVC pipes come out of unit. Look for wire coming off of cap, pry open and check for water. Some have sight glass. If water is in either of these, you can use shop vac to clear drain from outside where
water drains outside. Allso clear any water out of switch itself. If unit is in attic, look for water in emergency pan under unit. Next I would check refrigerant,Freon, Puron.
Most newer and better units are equipped w/low pressure cut out switches, Also look at t-stat wires to make sure there are no disconected wires, next I would check circuitboard. If breakers are not tripped and no water is backed up in drain.
Thanks.
Posted on Jul 08, 2010
Model 1ER50D fryer. When turned on, sound like contactor/relay pulling in and releasing repeatedly. Shut off disconnect, retried, unit on and works. Might work for a day/week, then does same thing.
When you hear the contactor repeatedly making and breaking-- do you notice the lights in the house dimming a bit? Do you have a way of measuring the voltage in your house, when you turn the unit on?-- Sounds like either low voltage problems, or a bad wire connection leading to your unit-- Can you measure the voltage at the unit, when it is making the Make and Break sounds?
Let's figure this out together... Mack B
Nov 22, 2016 | Heating & Cooling
CPLj24-1b
check outside breaker see if it tripped. thermostat, low voltage wire going to outside unit or contactor on outside unit bad.
Jul 06, 2013 | Goodman CPLE24-1 Air Conditioner
Outside unit won't come on. Drain pas appears dry/.
if nothing comes on (on the outside unit) when you turn on AC (and the inside unit runs ok) I would check the fuses and/or the breaker for the outside unit. I would suspect a fuse blown or a breaker tripped. It's also possible that your 'low voltage' (24V) thermostat wire has been cut (by lawn mower) or chewed into (by dog). If the problem is the low voltage wire you can easily splice it back together - just be sure all power is off.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
May 20, 2011 | Heating & Cooling
Hi - I have a Heil outside airconditioner unit - I had pulled out two wires from it and was wondering what those wires do and how to reconnect them - it was a thin black wire that had two wires coming out...
They probably come from the thermostat inside and go to the low voltage connections on the contactor in the outside unit. Those will be the connections for the coil in the contactor. Let me know if you have any questions.
Jun 20, 2010 | Heating & Cooling
New unit just quit no compressor, no fan, breaker not trip, blower unit working fine
Remove the access cover from the outside unit. Find the contactor. It is the part that has the high voltage incoming wires attached. There is a button/bar in the center of the contactor. Use a insulated screwdriver or a wood pencil and push the bar in. If the unit starts you will have to trace the low voltage circuit from the thermostat and air handler to the outside. 24 volts should be present at the low voltage contactor terminals via the defrost board. If you have 24 volts to the defrost board,turn off the outside power, remove the red low voltage wire from the defrost board then reattach it. The board may be tripped on a low voltage fault.
Report back here with your result.
Oct 18, 2009 | Carrier 38BRC036 Air Conditioner
I had power blink off for a couple of seconds and then came back on. The Amana air conditioner RCC30A2E seem to be On but no cool air was blowing. I check breaker it was ok. I preceeded to check...
Check for fuses in the 24v wiring. Was anything running outside? The 24V X-former is located in the air handling unit. check for voltage on the air handler. if present, check output voltage at X-former. You should have 24V
Oct 14, 2009 | Heating & Cooling
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Jul 14, 2009 | Ruud UBHC Air Conditioner
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
187 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
