Question about GE Security Simon 3 Wireless Home Security System
Need to change a battery for a simon 3 wireless scurity system. any suggestions
  • 74 Answers
It takesa 6VDC 1.2 AH battery. The battery is located in the back case.
AlarmProfessor.net
Posted on Aug 23, 2010
Changed battery on simon 3 monitor but now phone line is down
If, as you say, you just changed the battery and had no phones right afterward it's likely that you accidentally loosened the phone jack inside the back of the panel(accessible when unit is opened to change the battery). Remove and then re-insert the phone-jack clip, usually on a wide flat cable, and carefully tuck/fold the wires in the hollow area so no pressure is on the phone jack & wire;recheck phones.
Nov 25, 2012 | GE Security Simon 3 Wireless Home Security...
Simon 3 system not charing battery. Only .26 volts on terminals on the mother board. Does system have a fuse. I installed another new battery and it lost voltage by the next day so with the low voltage it...
There is no fuse on the Simon 3 board. If your transformer is good and measures 9-11V AC you charging circuit is gone and you will need a new motherboard. AlarmProfessor.net
Aug 13, 2010 | GE Security Simon 3 Wireless Home Security...
Cannot open alarm system to change battery
Push down on the tab at the top of the panel and open the front panel (Panel will say enter security code now). Put a slotted screwdriver in the top hole and depress to fold dowm the second door. Battery is inside the plastic case with two screws holding on the lid. The battery is a 6V 1.2AH battery
AlarmProfessor.com
May 23, 2010 | GE Security Simon 3 Wireless Home Security...
Where is the battery located in the Simon system?
Hi.
The battery is located inside the Simon. Use a flat screwdriver to remove the panel.
Here an online manual.See page 23.
Connect the battery BEFORE connecting the power transformer.
Regards.
May 08, 2010 | GE Security Simon 3 Wireless Home Security...
Module ok simon version 3
You need a new battery. 6VDC 1.2AH. The GSM module runs directly off the battery and it is no longer getting a full charge.
AlarmProfessor.net
Dec 30, 2009 | GE Security Simon 3 Wireless Home Security...
Sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Sep 02, 2009 | GE Security Simon 3 Wireless Home Security...
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
Remote panel not working after changing batteries.
you will need to reset the house code. it should be listed in the owners manual on how to do this.
Jun 15, 2009 | GE Security Simon 3 Wireless Home Security...
The alarm says module ok every few seconds
Reason: The reason why the sys is saying module ok is becasue of the panel battery. This is a common problem with simon 3 and thats why i would not suggest this sys to anyone. The module is the cell unit thats send the signal to the central station wirelessly and it gets it power from the batteries.
Fixes. The only way to fix this issue is by replacing the panel batteries.
Jan 13, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
181 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
