Question about Dishwashers
I replaced the fuse in my cda 195/1 dishwasher this morning the cycle started with no problems but blew the new fuse again soon after.
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
Posted on Dec 06, 2007
kermit854
  • 38 Answers
SOURCE: dishwasher blew electrics ,turned fuses
I would require more info before offering a solution. Please provide make/model of machine.
Posted on Aug 19, 2008
SOURCE: Hotpoint dishwasher BF1620 blew the main fuse
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Posted on Feb 07, 2010
  • 11 Answers
SOURCE: My Whirlpool GU2400XTP dishwasher keeps blowing
Are you replacing the wires along with the fuse? It is important to change the wires too as they are usually the cause for the fuse blowing. Be sure and get the fuse kit that includes the wires.
Is your water too hot? Hot water is fine but too hot of water can cause the fuse to blow over time. The temp should be somewhere around 120 F. Anything over 130 F is way too hot. I personally don't use a long high steam final rinse or high heat because over time the steam and cause the electronics to short as steam and moisture can get into the keyboard and inside panel.
Posted on Apr 08, 2010
Blew the fuse, now wont work.. and an electrical smell...?!
you will have to have a technician inspect the damage to see if it can be repaired before you make a decision on replacement
May 25, 2017 | Fisher and Paykel Dishwashers
Hi, my Siemens iq500 dishwasher cuts out mid cycle usually towards the second half of the cycle, it switches off and some times the display indicates the period of time remaining of the incomplete cycle....
Hello;
My name is Peter. I am a retired field service appliance technician.
It sounds like you had a bad thermostat and then blew the thermal fuse.
These parts are in the back of your washer, The thermal fuse is on you hot air duct and your thermal fuse is on the opposite side.
It could look like the following:
25322759-1gj2vudmgf1vp3qcvc3vmcwu-5-0.jpg 25322759-1gj2vudmgf1vp3qcvc3vmcwu-5-3.jpg 25322759-1gj2vudmgf1vp3qcvc3vmcwu-5-8.jpg
Dec 15, 2014 | Siemens Dishwashers
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Cda 350 dishwasher
I have a cda cw195/1 integrated dishwasher, the red light stays on and when I attempt to start it the cycle begins then stops and it continually beeps, all the filters are clean and there are no blockages any ideas
Jan 14, 2012 | Dishwashers
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Trying to access the pump and motor section
You should check the thermal fuse problem listed elsewhere on this site. My power went out on mine, and it was a cheap {less than $20 part} that snaps into the control panel. It eventually blew again a month later, and I replaced the heater element, and the new heater element came with a new board that was very easy to install. the new programming on the board actually speeds up the cycle due to a higher wattage heating element.
But what I didn't do the first time was replace the wires going to the thermal fuse that came with the replacement kit. (Apparently the OEM wires are too thin) Had I done that, I probably never would have tripped the fuse again and not bought the new heater element.
Jan 08, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dec 05, 2007 | Dishwashers
Fuse
If the fuse blew again then there is more than likely a problem with one or more of the boards components. First start by unscrewing the power supply and looking on the underside, you may see some burn marks. If you do then it is likely that the component above the burn marks has blown and needs to be replaced. If you do not see any burn marks then the best place to start is with the diodes on the board. If its still not working, e.g. the fuse blew again then it may be that the problem lies elsewhere on the power supply... Good luck.
Dec 06, 2005 | RCA RS2020 CD Shelf System
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
Owen Barnes
