Question about Arris SURFboard SBG900 (49402201900) Modem
How do i turn off the modem firewall? - Arris SURFboard SBG900 (49402201900) Modem
  • 45 Answers
If your modem/router is connected via ASDL or Cable then open internet explored.
look below the router/modem and it should have the IP address of the box (ie. http://192.168.1.1 )
Type this into internet explorer.
It should take you to the log on page.
Again read the modem/router though if you cant then try user name ADMIN and password PASSWORD.
This will log you into the modem setup. Click firewall/security and switch it off........Get the model of the modem then type it into google and you will find a more detailed guide of the unit.
Posted on Jul 08, 2010
Wireless signal loss with SGB6580 modem. this signal loss happens sporadically. what may be the cause?
If you log into your router by opening a web page and going to "192.168.0.1" log in, under "Firewall" turn OFF "IP Flood Detection" and "Firewall" this will fix that and make it like lightning.
Feb 19, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I want turn off firewall from my modem
to turn off windows firewall click on start and then control panel then open windows fire wall or just search there windows firewall and then click on of firewall and save changes and apply
if this information helped you then vote for it and thanks for using fixya
Apr 19, 2010 | Arris Touchstone 450a (CM450) Modem
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
Need to network SG300 Firewall and Qwest (Motorola) 3347-02 Modem
The modem needed to be set to a 192.168.x.x network, and the SG300 Firewall WAN port needed to be set to a dummy IP on the same network for it's IP, and the specific 192.168.x.x address for the gateway and DNS.
Nov 05, 2008 | Cyberguard SG300 (00852503000366) Firewall
Three Firewalls
You can't 'uninstall' the Windows Firewall, just deactivate it. Another option is to turn off the modem firewall (the strongest of the three, now two) and to activate the Windows one (the weakest but most annoying one). Now you stated that you can't use Internet Explorer but everything else was ok, skip IE, use Firefox or Opera.
Aug 30, 2008 | Computers & Internet
Westell 6100, to smart for job!
you have to activate DHCP in order to make the westell a modem "dummy" (it will just act as a bridge to the internet from your Linksys.
on the modem, go to a setting that is similar to "Public Routed Subinterface". dont choose anything that says "proxy" or "NAT".
find out the Linksys's IP adress by looking at the devices or computers list on the Modem's home page.
Now, put that IP adress on the setting "Public Routed Subinterface" (or similar). If it has a "Subnet Mask" option, type in "255.255.255.0". Also, If it has a "open firewall" or "bypass firewall" option, enable it.
If it does not have a firewall option, disable the firewall on the MODEM, not the linksys. This is also called DMZPlus mode.
If the above does not work, go here on the entire instrucitons for setting up the linksys with your modem.
Aug 20, 2008 | Westell Wirespeed LiteLine 6100...
Siemens Speedstream 4100b Firewall?
4100 modem dont have interface and needs broadband connection in your network connection page
4100b modem have an interface and can access interface by the IPADDRESS of 192.168.1.64 and default gateway of 192.168.0.1
by accessing the default gateway using address bar of internet explorer browser it will be easy to configure..
FIREWALL: all AT&T modems firewall are safe and compatible to use to OS that has a built in firewall
Jun 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Firewall
If you are referring to your connections built in firewall then goto network connections and right click on the item and select properties. If there is a built in firewall to the network device you will see it in the list. Uncheck the box to disable it.
Apr 28, 2008 | Siemens Se5954 (120-5954-003) Firewall
Speedstream Modems and Firewalls
No, I would suggest using a router with a built-in firewall. Internal modems don't have firewalls.
Dec 20, 2007 | Efficient Networks SpeedStream 3060...
FIREWALL ON P2P
There is no firewall in this modem, it's just a modem working in bridged mode. So the problem is in your router (firewall or port forwarding) or the firewall on your computers.
Sep 25, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Arris SURFboard SBG900 (49402201900) Modem Logo
481 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
