Question about Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515
Porta Cable CPF 6020 keeps triping curcuit breaker
  • edward woodard Jul 09, 2010
    when does it happen.when it first with no air in tank or after the first build up?
  • Porter Cable Master
  • 10,045 Answers
Check the start capacitor and the centrifugal switch on the motor for proper operation.
Posted on Nov 18, 2016
Gehl 4860 Skid Steer around 2007 ... ?Electrical Problem?
I would try replace the fuse. If triping a lot maybe hot or weak
Jul 11, 2017 | Electrical Supplies
Curcuit Breaker appears to be on but no power?
It sounds like something in that circuit is causing the overload. Disconnect anything that is in that circuit, flip the breaker, and one item at a time plug whatever was on that circuit back in until it trips again. Then try that item in a different circuit and see if it does the same thing. It could also be that the breaker is worn out and is tripping at a lower point that it supposed to. In that case you would have to replace the breaker.
Mar 04, 2015 | Electrical Supplies
Tcl 770 keeps triping power
Check to make sure the breaker is rated for the current draw of the dryer. If it is, you MAY have a bad breaker. Replace your breaker and If the dryer is still tripping the breaker, your dryer needs to be repaired by a qualified technician.... the heating element is probably burned up and shorting out.
Mar 02, 2014 | Hotpoint Dryers
Gfi breaker keep triping
Might be their job or it's gone.
1. replace the breaker (cheap and fast) ... they do go bad.
2. Remove everything from the circuit and try each to find the short.
Dec 19, 2013 | Cutler Hammer Electrical Supplies
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
Breaker keeps triping
Did it work trouble-free before?! Is it on its own circuit?! Are you sure breaker is of appropriate rating?!
Jul 09, 2012 | Refrigerators
Keeps blowing the plug fuse and/or triping the circuit breaker when plug in? Been working fine for 5 years until now
That must be the mains cable or the filter box as it enters the TV.
The TV is fused internally so suspect the supply cable or mains filter capacirors.
Hope that helps.
Dec 10, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
AC main Breaker
There are many things that would cause this problem. It would be best to have a qualified technician test your system to find the cause.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515 Logo
194 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
