Question about Williams 2509612 Ceramic Mid-Size Heater
New Fire Sense table top Patio Heater will not light. tank
New Fire Sense Patio Heater will not light. tank is full I followed all the directions and put it together correctly. It says push in and turn knob to pilot, then depress the pilot light button (igniter), nothing happens, it clicks it sparks, but it does not light.
  • Williams Master
  • 3,250 Answers
They will be air in the gas line , and the pilot injector being so small it will take ages for gas to come through , you need to purge the gas line undo a union or nut or pilot suppy to purge the line of air test joints after with soapy water .
Posted on Jul 09, 2010
My propane patio heater will not stay lit
Clean pilot first if this does not work it could be your thermocouple also check gas in tank
Apr 01, 2012 | Fire Sense 60368 Patio Heater
I have a Fire Sense Patio heater, it worked for awhile and no it will not light. You hold done the button it ignites and as soon as you let go of the button it goes out.. It is not the propane tank, we...
sounds like the regulator is vapor locked. turn everything off, tank, any switches on unit itself, any valves.everything. now disconnect the gas tank. let sit in the sun for a bit, so we cant get you going quicker. start at to tank, reconnect that. now follow the manufactures specs for operation.
Mar 15, 2011 | Fire Sense 02411 Standard Patio Heater...
Fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Apr 14, 2010 | Fire Sense 01775 Patio Heater
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Patio Heater
The pilot light has to heat up the thermocouple. Is the thermocouple in the flame? If so, the them. could be bad. Replace
Jun 28, 2009 | Endless Summer 1501 Patio Heater
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Williams 2509612 Ceramic Mid-Size Heater Logo
373 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
