Question about Haier CPN14XC9 Air Conditioner
Loud noise and turned off
This air conditioner made this horrendous loud noise the other night and shut off. I removed the venting tube and two small pieces of plastic fell out. They look like they were part of the rotating part of the heat exhaust. Can I fix this myself?
2 Suggested Answers
  • 274 Answers
SOURCE: Loud as Hell
Is it installed in a window? Check to make sure it is installed correctly. usually there is a felt or foam strip that is used to dampen vibration when you place it in the window. It also acts as seal to keep outside air and bugs out. If you place your hand at various locations on the unit does the sound go away? If it does then you know it is a vibration problem. Just add new foam or re-adjust the foam or gasketing it already has. If that doesn't work then try to locate the source of the noise. Use a mechanics stethoscope or even a cardboard tube from paper towels will work. Once you have located the source then you can tell the store what the problem is when you take it back and get a new one. Cheap air conditioners are noisy. Some more than others, it's why they are cheap. But your problem does sound like it could be a product issue.
Posted on Sep 25, 2007
We have a Surburban 10 gallon hot water tank in our RV. Today it started making popping noises. The burner keeps back firing and making loud popping/banging noises.
The burner tube is restricted. Try blowing the tube out with compressed air or cleaning the tube out with a small wire.
Oct 15, 2010 | Heating & Cooling
Air conditioner makes noises after it starts
I do not think that the battery change and the noise for the a/c is related, probably just a coincidence.
If the a/c makes a loud noise when it is turned up, I would try switching to vent to see if the noise is still there. If it is, then it is the ventilation fan likely located on the firewall or under the dash under some plastic paneling.
There is no reset button for the a/c.
Good luck on this repair.
Jul 17, 2010 | 2000 Honda Accord
2004 Saab 93: A/C doesnt turn off, car now wont start
remove the AC relay to shut the AC off all the time. Not sure why it wont start but you may havea security lockout. Fully charge the battery to proceed.
May 31, 2010 | 2004 Saab 9-3
My Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Dec 05, 2009 | Heating & Cooling
Loud noise in dryer, and no air coming out the vent
Check these things:
Unplug or turn off the power to the dryer and turn off the gas (if equipped)
Pull out and examine the lint screen
Pull the dryer away from the wall (carefully), disconnect the vent pipe (the 4" tube) and look for plugging of the vent line (you said the vent dampers weren't open)
Lastly, it could be the vent blower - this is located inside the dryer annd accessible from the back with the back cover removed. The blower could simply be plugged or it could be defective.
May 07, 2009 | Dryers
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Loud as Hell
Sep 25, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Fan making loud noise like it needs oiled
Most of the fan motors can be oiled. You will have the slide the ac forward and remove it from the case to access it. You will find yellow pull pins on each end of the motor, a lite drop or two is all that is needed.
Aug 16, 2007 | LG Electronic Window Air Conditioner
Haier CPN14XC9 Air Conditioner Logo
56 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
