Question about Fisher and Paykel DEGX1 Electric Dryer
The thermostat's working good and resisten too but is no heat yet is somethingelse can i check
  • Fisher and P... Master
  • 43,501 Answers
Hi, If you have a gas dryerthe thermostat's working good and resisten too but - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
the thermostat's working good and resisten too but - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingthe thermostat's working good and resisten too but - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
Frigidaire model# gler642as3
-You mean it work like normal but just no heat all ?
-If so check for heater element. It could be burn out.
Good luck
Mai
Dec 14, 2013 | Dryers
Dishwasher not heating
Check the heat circuit of your dishwasher. This will include your control, heat element, thermostat/thermal fuse, & sometimes your door switch. Check your thermostat/thermal fuse and heat element for continuity first. If all test good, go to your control and possibly your door switch. Check for voltage from your control and continuity of your door switch.Use the VOM. God bless you0999035f-139f-4f60-8314-2e1fc0f210a3.jpg
Apr 04, 2013 | Dishwashers
My honeywell ac panel went blank when i turn the heat on and the heat don"t start , the ac works fine
I would check a couple things lets start with the thermostat itself remove from the wall mount and check to see if the red and white wires are attached. Does this thermostat take batteries? If so replace the batteries. If still no heat make a jumper and jump out the red and white wires this should turn your heat on and now means that it is a thermostat problem. Purchase a new one and pay attention to all of the wires and where they go.Good luck
Dec 13, 2010 | Honeywell Programmable Thermostat Heater
A/c blower works, but only on high.
ITS THE SPEED RESISTENS THAT HAS BURNED,THE FAN HAS ONLY ONE SPEED , AND THE RESISTENS LOWER THE SPEED IN STEPS , GET A NEW ONE AND IT SHOULD WORK
Sep 26, 2010 | 2004 Pontiac Vibe
My nissan max continues to over heat. i replaced the radiator. but the mechanic did not replace the thermostat properly. do you think the over heating is due to needing a new thermostat?
not at all times can thermostat contol your cooling system, check for water leaks, water pump, radiator fans(check for speed) if all your cooling systems are good , replace your cylinder head gasket,
Jun 25, 2010 | 1995 Nissan Maxima
CT3200A101 FURNANCE WONT COME ON WITHOUT ME TURNING FUSE BOX ON-OFF-ON NEED TO SEE DIAGRAHM OF THERMOSTAT WIRING HOOKUP
THE VOLTAGE ON TRANSFORMER IS NOT ENOGH ,SOME TIMES THERMOSTATS HAS A RESISTENS THA IT BURNS,2 UNPLUG FURNES 10 SECONDS PLUG BACK ,3 HEATIG MODE VALVE OR ELECTRONIC PILOT FAIL
Jan 17, 2010 | Honeywell Programmable Thermostat Heater
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
I HAVE NO HEAT, i CHECKED THE THERMO FUSES ON BOTH MAGNETRONS AND THEY ARE OK. I WOULD LIKE TO KNOW RESISTENANCE READINGS FOR BOTH MAGNETRONS AND TRANSFORMER FOR WHAT THEY SHOULD BE
The reading would be almost zero.It is anywhere between 2 to 4 ohms for heater coils. and 3 to 8
ohms for transformer coils. This should solve your problem. E-mail to us for your comments.
Oct 05, 2009 | Microwave Ovens
Heater control panel
i played with the fuse alittle .i must of not had a good connection
Sep 13, 2008 | 1996 Ford Explorer
OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Fisher and Paykel DEGX1 Electric Dryer Logo
183 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
