Question about Culligan Under Sink Water Filter
Changed r/o 3 filters, no water capacity, 2cups max, added pressure-water stopped, removed pressure-still no capacity
    Problem Solver:
  • 8 Answers
Have the TDS or total dissolved solids tested. A good reading is 10% of the ifluent water. For example if the incoming TDS is 300parts per million, the product TDS should be 30ppm or lower. If it is higher than that, replace the membrane. Any local water treatment dealer should be able to locate and replace it for you.
Posted on Jul 21, 2010
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
Sep 27, 2011 | Karcher 2500 PSI Pressure Washer
3 beeps every 3 seconds
This usually occurs when there is a water supply issue. If you remove the front cover and expose the right side of the unit, you will see (at the top right) a panel with a black button on it about 1/3 the way in. USE A FLASHLIGHT to locate it.... there is an electrical shock hazard here.
Push the button and the beeps will stop. If the warning recurs, check for water pressure to the unit.
First, if you have a filter system, crack the nut at the entry to the filter just enough to see if water is present there. If not, go to the source and check the angle-stop... change it, or open it, as required.
If you have water at the filter inlet, do the same thing (after tightening the nut you loosened) at the outlet. No water?..... change the filters. Water present?... do the same at the entry to the ice machine.
Water at the entrance? Turn off the water and remove that fitting to expose the inlet solenoid valve and examine the strainer. If clogged, remove and clean the strainer.
Beyond this, you will need a technician to deal with the issue. Call the Hoshizaki factory at 1*800*438*6087 to find a factory-authorized service company in your area.
Jun 14, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Nov 07, 2010 | Culligan Under Sink Water Filter
In 3 buckets, two Buckets filled with 20 litres of water, first- 19 litres capacity(max) second- 13 litres capacity(max)-Filled third- 7 litres capacity(max) -Filled i need to fill 2 buckets with 10...
Assume the following:
B1 = 19 litres capacity
B2 = 13 litres capacity
B3 = 7 litres capacity
B2 and B3 are full. The answer is:
1. Pour 2 litres from B3 to B1
2. Pour 8 litres from B2 to B1
3. Pour the remaining 5 litres in B3 to B2
Another answer:
1. Pour 10 litres from B2 to B1
2. Pour 7 litres from B3 to B2
In both answers you will get 10 litres in two buckets.
Rate if this answer was helpful.
Thanks
Oct 22, 2010 | Computers & Internet
I have a Neorest 550 brand new. It wont clear the bowl with any paper in it, and the nozzle seems very weak?
Ensure the water supply is opened to full. This unit needs the max water pressure available to work properly. You can test the water pressure by running the water into a bucket at full capacity for 10 seconds from the cold water supply for the toilet. If you get 1.5 gallons or more then you have sufficient water pressure. If your water pressure is good remove the water filter from the toilet and ensure it didn't get clogged with something during installation. The other 2 possibilities are that the toilet is defective and requires repair or replacement or the wax ring may be obstructing the water flow. Try the simplest things first. I would also contact the manufacturer to trouble shoot with them as well.
http://admin.totousa.com/Product%20Downloads/H06939R%20NEOREST%20550%20BOWL%20UNIT%20ENGLISH,%20IM,%20V.01.pdf
Customer Service & Technical Support
Tel: 1-888-295-8134
custservice@totousa.com
techsupport@totousa.com
Aug 03, 2010 | Toto MS950CG-12 Neorest 500 Elongated One...
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
Water dispenser slow flow after filter change
I had the same problem when switching to Pur filters. There are two curved wedges inside the end that hold the filter away from its connection. It turned out that they were just a little to short, putting the end of the filter to close to the connection, and that's all it took to restrict the water flow. I went to the hardware store and found a thin plastic washer that would add some space (it was for a faucet diverter of some kind, thinner than a dime). It added just enough space for good water flow. Another benefit was it helped stop the icemaker line from freezing. A simpler solution might be to make sure to get factory-original filters.
Apr 02, 2009 | KitchenAid KSRS25IL Side by Side...
Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Culligan Under Sink Water Filter Logo
110 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Jim London
Jim London
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
