Question about Samsung HL-R5677W 56" HDTV
How to replace the color wheel in your samsung hl-r6167 dlp tv? what do I have to do to reset the Index Delay and CCD?
  • Samsung Master
  • 6,993 Answers
follow the below steps to replace the color wheel on your Samsung DLP:
  1. Put on the anti-static grounding strap to keep static electricity fromdamaging the internal components of the Samsung DLP TV. Turn theSamsung around so that the back is facing you. Make sure the Samsung isunplugged from the AC socket.
  2. Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
  3. Loosen the two screws from each side of the projection bulb's case.Pull the projection bulb out. Put the projection bulb aside. Use thePhillips screwdriver to remove the two screws from the left side panel.Pull the side panel and the circuit board attached to it out carefullyand put it down so that the cables attached to it have not been pulledout.
  4. Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable outfrom inside of the Samsung's case so that the center panel is free tobe pulled out. Remove the two large headed screws from the center panelwith the Phillips screwdriver. Remove the top two screws holding thepanel to the plastic case using the Phillips screwdriver.
  5. Slowly slide the center unit out a few inches. Take a picture of theprojector lens' positioning with the digital camera so that you can putit back correctly later. Unplug the two cables from the left side ofthe center panel. Unscrew the sensor switch using the Phillipsscrewdriver. Slide the center panel completely out of the Samsung andput it down on the clean cloth. Blow off the color wheel assembly withthe compressed air.
  6. Use the tweezers to remove the green plug from the top of the colorwheel cover. Use the tweezers to remove the two cables at the side thatare coming from the color wheel. Use the Phillips jeweler's screwdriverto remove the screws from the top, front and back of the color wheelcover. Slide the color wheel cover straight up to expose the colorwheel.
  7. Use the Phillips screwdriver to remove the three screws holding thecolor wheel to the color wheel assembly. Lift the color wheel up andout of the color wheel assembly and discard it.
  8. Position the replacement color wheel in the color wheel assembly.Reassemble the color wheel and reassemble the color wheel assembly. Putthe color wheel assembly back into position in the rear of the SamsungDLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back infor power. Turn the Samsung on and enjoy seeing the colors displayedproperly again now that you have replaced the color wheel.
I wish you good luck.
Posted on Jul 08, 2010
Replace color wheel on samsung HLP6163W
that needs experience of electricals first
Jun 10, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hlr5078wx DLP tv. rumbling noise and shaky picture
This is a color wheel problem.
I would recommend to use professional help because you can make more damage to the optical engine. Not to mention index delay have to be re-adjusted in special service menu after repair is complete.
Regards.
Russ.
Jul 23, 2010 | Samsung HL-R5078W 50" HDTV
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
I have a samsung dlp that makes a horrible buzzing sound and it turns off, all the lights blink and the color flashes in and out.
The problem is likely the color wheel paste the link attached for more info
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
DLP Image
In some cases,after installing a new color wheel, the speed of the wheel motor must be adjusted to obtain proper speed to ensure a satisfactory image. Unfortunately, you can not and should not attempt to do this adjustment yourself as the service menu contains many adjustments which if accidentily mis-adjusted may cause irrepairable harm to your TV. Ask a local samsung servicer to do an "index delay" adjustment in the service menu.
Jan 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R5677W 56" HDTV Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
