Question about LG Washing Machines
How do you replace the drain pump on the LG wm2277hw washer?
SOURCE: lg wm2277hw
Followed suggestions for LE message and it solved my problem with the OE message - cleaned the drain filter located on the front of the machine near the floor.
Posted on Sep 03, 2007
aborcass
  • 2651 Answers
SOURCE: Drain Pump Filter Leaks on LG TROMM WM2277HW
remove cover again , spend a few min cleaning the threads off, probly got some grit & dirt on them after water rushed out, dry them and a small film of vasiline over the o-ring wouldnt hurt nothing
Posted on Feb 23, 2008
  • 15 Answers
SOURCE: My LG washer, model wm2277hw gives me the OE on
You may have a broken pump impeller - you will have to order the whole pump (the filter on this machine allows BIG stuff through and it can ultimately damage the impeller)
Have you run this through diagnostics and determined if it is the drain or recirculating pump?
To run diagnostics:
Press and hold the "Spin Speed" and "Soil Level" buttons at the same time - then hit the power on the button
All lights should display - Press the Start Pause button throught the following cycles:
1 - Tumble clockwise
2 - Low speed spin
3 - High speed spin
4 - Prewash inlet (let it run for a few seconds to put some water in the tub)
5 - Wash Inlet
6 - Hot Water inlet
7 - Bleach inlet
8 - tumble counter clockwise
9 - Heater
10 - Circulation pump (see if your noise occurs here)
11- Drain pump (let this run until the tub is empty)
12 - Power off, finished
Once you figure out which pump, order the correct replacelement
Posted on Apr 27, 2009
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Posted on Jun 05, 2009
SOURCE: lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Posted on Sep 06, 2009
What are the intructions on how to change the "motor pump assembly"? I have the part and want to try abd save $ by changing it myself ... thanks
Here's a link to complete instructions to repair your washer. You may require a special tool to remove the installed pump. Click on the small pictures at the end of the page to view the detailed instructions. Here's the link;
http://www.managemylife.com/mmh/questions/228916-lg-washer-model-wm2277hw-code-oe-wont-drain
May 18, 2011 | LG WM-2277HW Front Load Washer
My lg frontloader will not drain. I read the comment, but how do I get to the impeler?
I just got through replacing this and found the service manual at http://www.appliancefactoryparts.com/content/pdfs/125459.pdf (it applies to several LG wasers, but this was a huge help to me to step by step get to the pump motor). Also, there are two identical motors (with impellers) on the WM2277HW, one pumps the dirty water out, the other recirculates the water back into the drum to help mix the "cycle water" with the appropriate liquid (after it is dispensed). Hope this helps
Sep 01, 2010 | LG WM-2277HW Front Load Washer
LG washer with OE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 27, 2010 | LG WM-2277HW Front Load Washer
My lg WM2277HW is not draining water. It's filling with water and spinning but not draining the water. An oe error is being displayed. I checked the hoses and they seem fine. I checked the filter and there...
Remove and inspect the drain pump. (access is from the bottom of the washer once you remove all screws holding the pump housing in the front)
If no debris found when removing pump or pump impeller is damaged - replace. PArt number 4681EA2001D.
If found debris when removing the pump - reassemble and check again.
Good luck.
Jul 02, 2010 | Washing Machines
Need to see diagrams for removal instructions for the drain pump on lg washing machine wm2277hw
LG WFS7012ds model washing machine while starting of washing operation after start 5 min machine geeting stopped with beep sound
Jun 21, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
I have an LG WM2277HW that shows a ''DE'' problem code
Not fully drained within 10 minutes. check the pump for strings or small items . Check drain DE=drain error.
For a manual go HERE
Nov 06, 2009 | LG Washing Machines
I have the LG Tromm, WM2277HW. I followed the
I took the entire washing machine apart. I checked the drain pump as the repair service said I needed a new one, as well as a rear and front drum, shocks rear bearing assembly. Would you believe the only thing wrong with the unit was that the drain pump was clogged at both ends. Machine is running fine and not throwing the LE Code. The repair service (LG recommended dealer) should be shot for telling me to throw out the unit.
Aug 01, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
387 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
