Question about Linksys Cable Modem
Receiving wireless signal but unable to connect to the Internet
Getting wireless signal from the Linksys 802.11g 2.4 GHz however unable to connect to the Internet. Was working fine before. Can anyone provide a solution to the problem
  • 3 Answers
You have to set your router into mixed.....and set your gateway into LAN & WIRELESS...
Posted on Aug 09, 2010
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Just purchased a Cisco Linksys E1000 Wireless-N Router. I am unable on my wireless laptop to connect to the internet. The Error I am getting from my computer is: The settings saved on this computer for the...
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
I have defined 2 networks, one for the G and the other for the N channel, only the one for the G gets connected
You have WRT610N dual band router . it works on both 2.4 GHz and 5 Ghx bands at the same time.
Both the bands are N bands.
2.4 GHz and 5 GHz band are capable of working on N signals.
Now on your computer you are able to see only the 2.4 GHz signals but not the 5 GHz signals.
To see the wireless signal on the computer , your computer should have 5 GHz compatible wireless adapter.
If you have 2.4 GHZ adapter on your computer then you won't be able to connect to the 5 Ghz signal.
Open the Device manager and under network adapters you will see the wireless adapter. Check if it is dual band wireless adapter.
Click here for more information
Aug 04, 2010 | Linksys WRT610N Wireless Router
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Getting a router signal, but no internet
Have you check if you have a valid IP address? You could run IPconfig in the DOS window to verify this. If you have a valid IP address, try pinging the default gateway (You should be able to ping it.) Then, try to ping a website. If you could ping a website or URL but still can't browse check your firewall settings and optimize your browser.
Please post here what happen.
Thanks and regards,
BeHar
Jan 18, 2009 | Linksys (WRT54GC) Router
Unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Dec 21, 2008 | Linksys Computers & Internet
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys  Cable Modem Logo
227 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
