Question about Gateway 420GR PC Desktop
Can I hook my Mac Cinema HD Display 2005 model to my gateway 420GR? If so, what do I need in the way of an adapter?
    Master:
  • 515 Answers
Windows PC and graphics card that supports DVI ports with dual-link digital bandwidth and VESA DDC standard for plug-and-play setup. You can check the specification of the graphic card and see whether they support those. For the cable if they are not in the box of the display, you can check the following ones.
http://www.dviator.com/en/DVIator.html
http://www.gefen.com/kvm/dproduct.jsp?prod_id=1203
Posted on Jul 09, 2010
Testimonial: "Thank you, I am looking for one now..."
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
22" Apple Cinema Display doesn't power on
This may be an issue with the display detecting the wrong video format or is using an unsupported resolution for this Apple Cinema Display 22"
Procedure:
• Make sure your Mac is turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Mac to start up.
If that does not help here is additional support reference from Apple regarding its LCD displays:
Apple Support Link:
Power Light Flash Issues
Let me know if this helps!
Regards,
-Mactechtrainer
Jul 02, 2009 | Apple 22" Cinema Display Monitor
The screen is half blue
You many need to reseat the Apple DVI to ADC Adapter that is connecting your Apple Cinema HD 23" to your Mac.
If that adapter is not properly seated, it can cause a color distortion with the display. Also, if the adapter is damaged, that can also impact proper resolution and color balance.
To try and resolve this issue for you, I have a procedure I would like you to try:
-SAFE BOOT MODE-
I am going to have you take your Mac into Safe Mode to see if we can't isolate what may be affecting your display's resolution.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Here is an additional support reference for troubleshooting Apple Cinema Displays color or distortion issues.
Apple Support Link:
Calibrating your Apple Cinema HD Display for color accuracy
This should help. If it does not let me know.
Regards,
-Mactechtrainer
Apr 24, 2009 | Apple Cinema HD 23" LCD Monitor
Gateway 420gr sata driver in XP
If you downloaded all the drivers for you 420gr motherboard at the Gateway site then you should be all set.
You didn't say if your hard drive was operating correctly or not?
Mar 30, 2009 | Gateway 420GR PC Desktop
Sabrent 5 in 1 adapter usb-dsc5
Gateway hard drive need to be "slave"
usb need to be inserted before turning on the PC.
Oct 05, 2008 | Sabrent Computers & Internet
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Gateway 420GR PC Desktop Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
