Question about Linksys Wireless-G WRT54G Router
I am trying to set up a wireless lan access point instuctions tell me to use ip address to bring up configuriation screen
  • 153 Answers
"your router should be power on to perform this operations". Follow this steps bro. 2.reset your router configurations by pressing the reset button at the back of your router on the left side of the WAN port.3. when you are done pressing the reset button, wait 1minute to secure the configuration to roll back to its default configurations. 4.launch Browser "Mozilla Firefox". 5.in your locator bar or URL bar type "192.168.0.1 or 192.168.1.1" as a default ip address to log-in to your router at the top of the browser. 6.the authentication box will appear in your screen to input your router security log-in. 7.for user name just leave it blank. 8.for password type admin as a default password. 9.the router internal configuration setting will appear in your screen. 10.to enable wireless connection, select "wireless" at the upper menu list of the page. 11.set your SSID any name you want to name for your wireless connection then save. 12.for LAN you can just leave it on its default configuration.
Posted on Jul 20, 2010
    Sniper:
  • 126 Answers
I am not familiar with connection process, but the speed of the internet can be evaluated from, http://www.ip-details.com/ which gives us all the data we require.
Posted on Aug 19, 2010
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
Can I set the WNR1000 as an access point
Yes, You can set it as a wireless access point. All you need to do is follow the steps below.
1. open internet browser, enter on the address bar http://routerlogin.com
2. username is admin, password is password.
3. Go to wireless, change the wireless settings like the ssid and setup the encrption. Go to LAn settings under advance.
4. Disable the dhcp server and change the ip address of your WNR1000
ex. You plan to connect your wnr1000 to a w ired route rwith an ip address of 192.168.1.1. You can set the wnr1000 to 192.168.1.x ( except 1)
Save the changes,
Plug the access point wnr1000 to the lan port on the main router and the other end also on the lan port on the wnr1000.(LAN to LAN)
It should be working now as an access point.
Kevin
Jul 03, 2010 | NetGear WNR1000 Router
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
How to configure it for point to point network
I'm assuming you have two of these.
Configure one as an access point. Choose a frequency channel, an SSID, a power setting, and an encryption method and password. Set its administrative password. Give it an IP address in the proper range of your LAN, and attach it to your LAN switch. Point it properly.
Configure the other as a bridge or a bridge-router, as you require. Tell it what SSID to find, set its power setting, and give it the same encryption method and password. Set its administrative password. Give it a different IP address in the proper range of your access point's LAN. If you configure it as a bridge-router, configure its own LAN side as you wish. Point it at the remote access point, and within about 30 seconds it should pick up on the signal and you will have a point-to-point network.
Sep 03, 2009 | EnGenius EOC-3220 EXT (EOC3220EXT)
Dwl-2100ap will not update firmware
1) Reset do default the device (rear reset button)
2) Set your PC a IP like 192.168.0.xxx (defaul IP address for DWL-2100 AP is 192.168.0.50)
3) Connecto via browser to 192.168.0.50, defaul login
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and selectInternet Protocol (TCP/IP), click properties, click set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
If this information can help you, please rate me ;)
Aug 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Can't ping to tp-link wireless
do one thing put the access point in the universal repeater mode and the put the same ip address of the LAN same means same series for example you using the 192.168.1.x you put the same series ip address. all the same setting of the router or modem wireless or wired all setting shod be same settings
Apr 09, 2009 | Computers & Internet
WAP4400N access
Do you have a DHCP server, like on your router, or on another computer on your LAN ?
If you don't know if you have a dhcp server or not... in windows, you can go to: Start>run>cmd, then type: ipconfig /all
That will tell you what ip address your dhcp server is.
If so do you see the access point trying to get an address? Check your logs, if you have a DHCP server chances are the access point (AP) already has an address.
Another thing you can do, is hold... i think it is a red button in the back, if you hold it for 30 seconds i think.. it will reset your AP back to its default settings.
Jan 11, 2008 | Linksys Business Series WAP4400N...
Linksys Wireless-G WRT54G Router Logo
56 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
