Question about KitchenAid KUDS40CVSS Builtin Dishwasher
Dishwasher does not work, whats wrong? completely hooked up (water, electrical) seems as if it has no power.
2 Suggested Answers
  • 7 Answers
SOURCE: I have a Kitchenaid Dishwasher about 5 years old.
Removed power line from panel board # 11 as seen in appliance parts pros and shocked the board. It came to life and completed a cycle nominally. Then it died again. Tried to shock it again and sometimes it works but most times it doesn/t. Similar posts indicate a transistor failure in the board assembly. The board is easy to replace and costs about 90$. I'm replacing mine. Turn off power. Remove #15 torx screws (6) from the upper cover and lean panel forward. Remove board power . Diagram where connectors go back. Board is held in with 6 clips. Gently push clips open on one side and tilt board to remove board and ribbon cable. Reverse installation.
Posted on Sep 26, 2009
Connectingit hooking it up
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
2q== 9k=
Apr 10, 2014 | Dishwashers
No water. valve seems to work. switch seems to work. No power to switch or valve. is there something wrong with the controller?
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 02, 2011 | GE Nautilus 24" Built-in Dishwasher
My dishwasher has always washed in cold water never had any hot water why is that
Probably because it is hooked up wrong...
The water feeding it should be hot water... meaning it should be hooked into you hot water piping, not the cold water...
The dishwasher will keep hot water hot but it is not powerful enough to heat the cold water up...
heatman101
Jul 16, 2011 | Servis 23 in. M4306 Free-standing...
We have an ariston LS 620A dishwasher. For the last year every few months the dishwasher seems to cause a short in our electrical box causing all the power to go out in our house. It is only when the...
The problem seems to be water seepage into the electrical contact.
If the heater has lost its insulation this problem could accur
( element to body )
Disconnect the heater and give a try without any load and soap. If it
performs OK , you have to check the heater by removing from the
machine. Mainly I suspect water seepage into the electrical system.
Aug 30, 2010 | Ariston Technologies Dishwashers
Dishwasher not filling with water. It is not the float. GE PDW 8480 Dishwasher
It could be the fill valve or that the power is not getting to the fill valve. Pull the bottom panel and find where the water line hooks up to the valve. There should be an electrical connector on the valve. First, listen when the dishwasher is at the cycle where it should be calling for water, to see if youhear a click of the valve opening or water running in. If not, and you have a volt meter, pull the electircal connector and check for AC voltage across it when the dishwasher is off - it should be 0, and when the dishwasher normally would fill - it should be something above 0 - it might even be 110v. If the voltage is ok, but the valve is not working, you need to replace the vavle. If the voltage stays 0, then something is wrong in the timer/control circuitry.
Mar 13, 2009 | GE Dishwashers
Beatstherest again
well if the wire connection/leads arent fully connected to the valve its possible the valve would not energize. (2 wires leading to the valve in which oyou hooke up water supply) perhaps came loose in shipping/delivery
Nov 04, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Not draining
Are you sure your drain system is not clogged or restricting water flow ? When you say youtook off the hose off under the sink and it seemed to be lots of water running on the rise cycle .. that suggests that you may have a restriction after the drain hose in your house drain system. ...
Some other considerations..
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used
Hope this helps you...
Sep 03, 2008 | Dishwashers
Subject is Bosch dishwasher SHU6800. There is a soap residue left on dishes. Residue is not visible. Using two glasses taken from a recently completed wash cycle I rinsed one under tap water and then...
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Aug 17, 2008 | Dishwashers
Dishwasher problem
If the cycle doesn't complete, check these:
1. Water-heating cycle
2. Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
 thanks for using FixYa
Feb 10, 2008 | Kenmore 65924 Electric Dryer
KitchenAid KUDS40CVSS Builtin Dishwasher Logo
37 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
