Question about Nintendo Wii Fit for Wii
Balance board repeats step off me and press button a
    Genius:
  • 1,340 Answers
You need to sync it,it sounds like.Open the battery compartment to the fit,and the large door on front of the console.Press the red sync button on the fit board then press the red sync button inside the door of the console.It may take a couple tries.I can't remember how long it gives you but it will work.Good luck and game on!
Posted on Jul 27, 2010
4 Suggested Answers
  • 80 Answers
SOURCE: Wii Balance Board thinks I'm on it all the time!
Make sure of a couple of things and try again -
If you are on semi-shag carpet, try using the little foot extenders. They may not seem like much but they can help.
If you are on moderate to thick carpet, you may need a board to set the Wii Fit Balance Board on.
If you are on a wood floor, you can (but don't have to) remove the little foot extenders.
Another little gremlin can be in those silicone covers. If you have one, I'll bet that's the culprit. As nice as they are to keep the board clean, they can actually attach to the non-moving part of the scale (the bottom) to the moving (surface) part. Be sure that your silicone cover is not interfering with the normal movement of the board.
Finally, be sure that you are always using YOUR setting while exercising or it will not be calibrated correctly. Also be sure that when you start, you are not on the board when it calibrates for the first time after turning it on. If the weight on the board differs by about 5 lbs or more than what it thinks you weigh, it will pitch a little wii fit.
I hope you find this advise helpful. If not, though, please don't label this advise as "inappropriate". A "Thanks for Trying" would be just fine.
Thanks for using Fixya.
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: my wii fit balance board says to step off and press A
You need to load it, stand on the board, step off, and then press A. I have a WiiFit and that happens. It expects you to be standing on it.
Posted on Mar 27, 2009
  • 4 Answers
SOURCE: im having trouble with my balance board keeps
the board is most likely defective, I have seen several boards with this problem. I believe it is related to the defect in the right rear foot sensor. try using the board check test to see if it will show the defect and replace the board.
Posted on Apr 13, 2010
KENWOOD KDC-215S HOW TO SET BALANCE
Step 1:
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
Hope this helps.
Cheers,
Scott
Jan 21, 2013 | Kenwood KDC-215S CD Player
I have a wii balance board, the batteries ran out so i changed them -now the board will not work. Ive tried pressing the red buttons together but still no joy. my neighbour is having the same issuses. Why...
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete
click here to download repair guide if u need
Dec 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
follow this
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Jul 20, 2010 | Nintendo Video Game Consoles & Games
Im having trouble with my balance board keeps repeating step off and press a.after a lot off turning the board over and over if it doesstart it wont give proper weight
Mar 23, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
Please step off press A - constantly repeated - why???????????
If the Wii Balance Board fails to operate, or operates incorrectly, follow the steps below before seeking
assistance.
A. Check the batteries.
B. Check to be sure there is nothing pressing against the bottom.
C. If you are using it on soft carpet, put the foot extensions on.
1. The Wii Balance Board does not respond.
• Make sure the power is turned on. The blue Power LED should be lit if the Power Button has been
pressed. (The Power Button faces away from the TV.)
• Make sure the board has been placed correctly (see page 6).
• Make sure the batteries have been inserted correctly and are not been depleted.
• Make sure the game you are playing is compatible with the Wii Balance Board.
• Review the synchronization procedure on pages 7-8 and make sure this has been done correctly.
This procedure must be done for each Wii Balance Board compatible game.
• If, after verifying the steps above, the Wii Balance Board does not work, try the following:
1. Turn off the power of the Wii console with the POWER Button on the front of the console.
2. Unplug the power cord from the wall outlet for a few seconds, then plug it back in again.
3. Turn on the power of the Wii console.
4. Repeat the steps in this Operations Manual for setting up the board.
If the Wii Balance Board still does not work, follow the information at the bottom of this page.
2. Control of the Wii Balance Board is inconsistent or seems incorrect.
• Review the Instruction booklet for the game you are playing to make sure you are performing the
correct actions for that game.
• Try using the Wii Balance Board foot extensions if you are using the board on carpet (see page 10).
• Make sure there are no people or other objects between you and the Sensor Bar.
• Avoid interference from other devices. If communication seems to be affected by other devices
(wireless LAN, microwave ovens, cordless devices, computers) move to another location if possible,
or turn off the interfering device.
If the Wii Balance Board still does not work, follow the information below.
If the Wii Balance Board still does not work, an operational check procedure is available
in the Options Menu of the game you are playing. See the Instruction booklet included
with the Game Disc for more information. If your Wii Balance Board does not operate
correctly after all of the above steps, visit support.nintendo.com for assistance and
additional troubleshooting and repair options or call 1-800-255-3700.
Jul 19, 2009 | Nintendo Wii Fit for Wii
Wii fit balance board
Make sure that whatever game you are playing (ie: Wii Fit) is fully loaded before pressing the power button.
If the light continues to go off, you may need to re-sync your Wii Fit balance board to the console. To do this, load Wii Fit, and when the program is running, press the red button inside the battery cover. Immediately press the same type of red button inside the panel on the Wii located between the eject and reset buttons (on the face).
If these steps don't work, try fresh new alkaline batteries and repeat.
Note that there have been lots of complaints using rechargable batteries. I've had the same alkalines in my unit for 3 months now. If insistent on using rechargables, I suggest buying several of the same battery and a quick (15 minute or 1 hr) charger as opposed to ANY after-market recharging product. It will be cheaper and more reliable.
Apr 07, 2009 | Nintendo Wii Fit for Wii
My wii fit balance board says to step off and press A
Mar 27, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Balance board
resinc the board
Dec 25, 2008 | Nintendo Wii Console
Power
    Try these steps!
Sep 09, 2008 | Nintendo Wii Fit for Wii
Wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Aug 01, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
592 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
