Question about Maytag PYE2300AY Electric Dryer
So I emptied the lint trap as I always do before putting in more laundry and start the dryer. When the dryer stopped the lint trapped was overflowing into the dryer. I emptied it and restarted the dryer hoping to get the lint that was overflowing into the dryer, off the clothes and into the lint trap. However it was overflowing again! There was a foul smell that actually burned my nose coming from the clothes. The clothes were not as soft. Turns out a pair of denim shorts had holes in them and cotton t-shirts ripped at the slightist tug. What is wrong with my dryer?? It still spins and is still warm.
    Sergeant:
  • 216 Answers
This sounds like you have a blockage in the dryer vent tube. This is the plastic or metal exhaust tube the exits the dryer either in the back or the side. If you know where the vent exits the house you can go outside and with the dryer on you should be able to feel warm air exiting the vent. You might also look to see if a animal has made a next in the outside vent. You may also need to remove the exhaust vent from the back of the dryer, Generally it's connected with a few screws or a ty strap. Once the vent is removed you will physically need to look in the vent to see any obstructions. Remove anything you find. Once again start the dryer on no heat mode if you have on or on low heat and feel if you have any air coming from the vent with the hose or tube removed from the back. If no you have a good air flow then you have cleared the vent, no reconnect the vent tube and recheck back outside. You should have air flow through the outside vent, if not you will need to remove the vent obstruction. If you find that you have no air flow and the dryer drum is turning then you have a broken blower wheel.
Posted on Aug 05, 2010
Lint trap not collecting lint
the lint trap is a thin gauze material and should trap plenty of lint---are you sure its there or in place properly?
Sep 23, 2012 | Estate TEDS840JQ Electric Dryer
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
The dryer keeps stopping (the timer skips from 50 mins to 10 mins in secs) AND what worries me the most is, I haven't needed to empty the lint trap.
some were he has blocked the out let for lint trap the reason its stopping is its over heating don't use untill sorted it will cause a fire if left
Iget alot of lint in my laundry cant find lint
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open). All dryers have a lint trap (building codes probably even require it).
May 15, 2010 | Amana NAV2335A Top Load Washer
Lint problem
Yes, check filter assembly is not blocked.
Mar 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
Red light on,check filter
Is this a ventless dryer? I.e. a condensing dryer?
If so, there is a filter that filters the lint out of the water in the condensing unit. Check your owner's manual to find out how to service this. It is usually a little door on the front, bottom of the unit.
If it is not a ventless dryer, then the only filter I know is the lint screen.
Good Luck!
Oct 10, 2009 | LG WM-3677HW Front Load Washer / Dryer
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Dryer Lint Trap Not Catchin Lint
If you have the ability to move your dryer away from the wall and look at the hose located at the bottom of the unit.
1. Take the house off it might be clogged 2. check for ang gaping holes in the lint screen
Jan 19, 2009 | Maytag Performa PAV3200
Maytag PYE2300AY Electric Dryer Logo
116 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
