Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
Subwoofer stopped I think my subwoofer stopped working on my surround sound system. The cables are intact, there are not other problems with any of the other speakers. Any thoughts?
    Master:
  • 501 Answers
The subwoofer only works when deep bass signals are sent to it.you may not have had any in the music/movie you were watching..check yr on screen menu for settings
Posted on Jul 08, 2010
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
Can't get cable sound to run through surround sound
You would have to have a cable box, from the cable box, you would hook up the yellow to your tv, and then the red/white audio would go to the subwoofer on your DVD765 where it is labeled (TV), you then hit the switch on the subwoofer to TV. Another option is if your TV has audio output, you could just run RED/WHITE audio from your tv to the back of the subwoofer where it is labeled (TV).
Jan 30, 2013 | Coby DVD765 Theater System
We have a jvc home theater surround sound system and the subwoofer just stopped working. the model number for the sub is sp-pwc30 and we want to just replace the subwoofer any ideas how to get one?
Depending of the type of Subwoofer that required your system.
A) Amplified Subwoofer. (With 110volts A.C. cord attached to the sub)
The subwoofer electronics circuit needs repair or change.
You will find a compatible subwoofer for this type of subwoofer in audio appliance stores.
B)Not amplified Subwoofer (No 110volts A.C. cord attached to the sub)
Bring your sound system to a technician to have the soldering remaked to the devices bolted on the main heatsink.
And have the Subwoofer checked too.
This type of subwoofer can mostly be buy in kit with the satellites speakers.
And need to match thee impedance of the output of your system.
Search for ( 4 ohm or 6 ohm 8 ohm ) near the Sub outlet behind your system.
Spider Guy
Mar 15, 2010 | Audio Players & Recorders
How do i connect my subwoofer to my tv
Have you tried connecting an AV cable from yoursuboofer to your TV?
If so, what type of connection cable does your Woofer have?
Is your subwoofer apart of a surround sound system or is a separate unit?
Feb 10, 2009 | Harman Kardon AVR 300 Receiver
Subwoofer FPS 1000 4.1 sound bad
hello,
I had a problem closely with my FPS 1000 4.1 sound works four point surrond : my subwoofer sounds a metallic noise when the bass are loud.
Maybe it is the same problem ? :
It were vibrations that go through the subwoofer and cause the noise.
Check the four screw well (the four hole on the back of the subwoofer). Put your finger on them to clog them and hear if your problem is solved.
If yes, put scotch on them.
Secondly (i think you have disassemble your subwoofer), you can put silicon joincture on the box near the circuit, under the translucides cables. (the box where there are the plugs). >> if there are any hole between his box and the speaker, there will be some metallic noise (vibrations trough the box and the back plugs).
bye
Jan 17, 2009 | Infinity FPS-1000 Speaker
Subwoofer humming/buzzing
It sounds like one of the internal solder welds to the cable or a/v connections inside the cable box is bad.
Dec 19, 2008 | Bose Acoustimass 10 III System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
I have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.When i plug everything in and power it up i get a quick 3 second burst of sound and then it stops,but the...
i have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.Lost the cables, can somebody help me, dont know where to get them???......original cable part # are
ADX-7239 this is the system cable A and (rectangle connector)
ADE-7023 this is the subwoofer cable B.....(round connector) 8 pins both
is there any compatible cable....thanx apprecieate ur help!!!
Jun 30, 2008 | Audio Players & Recorders
Subwoofer not working
you have to reset the receiver, i had the same problem, works now, it's great, should be in the instruction booklet. I think it was, hold the power button while you disconnect it from the wall, not too clear but check the booklet in resetting system
Nov 01, 2006 | Kenwood VR-406 Receiver
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
244 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
