Question about Symbol LS 4071 Handheld
Symbol p370 scanner weak signal
I have a couple of these p370 wireless scanners. One has a significantly weaker signal (cannot be used as far away from the cradle) than the other. Could this be a dodgy battery? Problem with the scanner itself? Trying to get to the bottom of it. Many thanks.
Try changing the frequency that the gun uses. Ususally 83. 82, 81 are the best, but others might be better depending on electromagnetic interference.
Posted on Jul 28, 2008
Scanner scans incorrect barcodes to intuit pos on
Needs to be programmed, cal me 847-847-7835 x202
Sep 25, 2013 | Symbol P370 Handheld
I have a newly aquired P370 Symbol Scanner and I cannot get it to automatically "enter" (carriage return) after a barcode is scanned. I have reset the default application, and scanned the Suffix...
One of four reasons for this:
1. The scanner firmware does not support it. Firmware less than rev F does not support the enter- I do not think this is your issue though. You check the firmware revision in the main menu option 4 or scan the barcode out of the Product Reference Guide.
2. Custom firmware on the scanner prevents the enter from being sent. Again check the firmware. If it starts with anything other than an N you should consider sending the device in to Motorola to have it upgraded to standard firmware.
3. The cradle firmware is less than G. If the cradle is less than G it will strip the enter off of the data being sent. If the firmware in your scanner is new enough you can check the revision using menu option 4 in the scanner.
4. An MCL application on the scanner. If you see something other than SKU: on the display the scanner has a custom application on it. The application would have to be modified to add the enter or removed from the device.
Feb 07, 2011 | Symbol P370 Wireless Barcode Scanner
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
I NEVER HAVE HAD A PROBLEM WITH MY SCANNER UNTIL NOW,A SYMBOL INDICATING SCAN POPPED UP IN FAR RIGHT CORNER. AND EVERY TIME IT IS RECEIVING IT LIGHTS UP AND MAKE A BEEPING SOUND. AND THEN THE WORD...
Press the function key + the symbol that looks like an eye with cross hairs (signal stalker mode) and turn the function off. To set the options in signal stalker, press function + signal stalker for 2 seconds.
Jun 25, 2010 | Radio Shack Pro-84 Handheld Scanner
I have a p370 scanner and i cant figure out how to connect the partnership between it and my computer
Copy and paste the following link to your web browser address bar:
http://support.symbol.com/support/browse.do?WidgetName=BROWSE_PRODUCT&TaxoName=SG_SupportGoals&BROWSE_PRODUCT.isProductTaxonomy=true&BROWSE_PRODUCT.NodeId=SG_P370_1_2&BROWSE_PRODUCT.thisPageUrl=%2Fproduct%2Fproducts.do&id=m4&BROWSE_PRODUCT.TaxoName=SG_SupportGoals&NodeType=leaf&NodeName=P370&BROWSE_PRODUCT.NodeType=leaf&NodeId=SG_P370_1_2&AppContext=AC_ProductPage&param_document=sp
The page offers manuals and a configuration utility for your scanner.
Best wishes,
Graemevm
Dec 17, 2009 | Computers & Internet
Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Dec 02, 2009 | Symbol P370 Handheld
How do i enter and ascii value on the keypad of the p370
Sure, there is a easy way to get this ASCII value entered. Please contact me. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Sep 01, 2009 | Symbol P370 Handheld
Symblo Scanner not pairing with Base
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
Jun 01, 2009 | Symbol P370 Handheld
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Symbol LS 4071 Handheld Logo
274 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
