Question about Dometic RM2620 Refrigerator
Dometic freedom rm2612 refer wont cool freezer is doing fine. Need to troubleshoot. Fuses look fine. Is my black box out? How do i test this? Actual model is dometic freedom rm2612
3 Suggested Answers
  • 163 Answers
SOURCE: dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
Posted on May 10, 2009
woodchuck789
  • 4059 Answers
SOURCE: Dometic RM2612..Replaced Thermister, was cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jul 12, 2010
Testimonial: "Thank you for the information...the refrigerator is located at camp, and next trip I will try your suggestion...Thank you."
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Dometic RM2811, frezer works great, frig. wont get cold?
Here is a link to a Service manual for RM2612 to RM2852 There is a list of items to check in the manual. Other Manuals and info, HERE I am here should you have questions, Thanks Sea Breeze
May 20, 2013 | Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Dometic RM2612..Replaced Thermister, was cooling excellantly, now freezer works well but no cold in bottom of frigg? What may cause this?
Jul 12, 2010 | Dometic Refrigerators
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Sep 23, 2009 | Refrigerators
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
My 1995 Dometic 2611 runs OK all day but not at night
Yes more than likely the cooling unit is going bad. If your boiler tube is hot the cooling unit is no good. Your frig is 13 years old, it has reached its life span and beyond. A cooling unit or a new frig can be purchased from www.coachtech.info. Just send them an e-mail.
Feb 28, 2009 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2620 Refrigerator Logo
258 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
