Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My LG wm2233hs won't start won't even turn on how can I fix it?
  • 6,784 Answers
HI. This will be a main PCB fault. The main board has failed. Anytime you have a fault this serious, it will always lead to the main PCB. With that said, I will need you to check your home breaker box for a tripped circuit breaker. Make sure that every breaker in your home box is set to the on position(closed circuit). You have stated in your post that this unit is completely inoperable"wont even turn on". If this is correct, the main PCB will need to be replaced if the circuit breaker is in the on position and not tripped. Also, make sure the power cable is plugged into the socket, properly. If needed, use a voltage meter to test the home plug socket on the wall to verify that there is indeed power running to the unit, as designed. Once you have verified that the power is getting to the unit, this will confirm the failure of the main PCB. This board is located and mounted on the inside wall of the cabinet. Some disassembling will be required to extract the affected part. The part number for your new board will be EBR32268004.
Posted on Jul 08, 2010
2 Suggested Answers
SOURCE: LG TROMM WM2233HS won't start
Obviously I switched the breaker wrong. We switched the breaker again and it worked.
Posted on Apr 02, 2009
My LG cell phone doesn't turn on for me. I've tried lots to get it to work but it won't work! Plz help!!!!!!!!!
Hi,this problem is not a single question and doesnt have a single answer,all inside circuit include battery must be checked, may be the battery is gone may be mother board problem or break up maybe dust or humid problem and or even software problem,go to certified repair store to fix it for you
kind regards
Apr 17, 2013 | Cell Phones
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
My LG thrill suddenly lost it's signal, and now
I had the same issue. A factory reset fixed it.
Dec 26, 2011 | LG Cell Phones
Apr 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
128 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
