SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX"
1. Press "Amp" button (right side of remote - 1/3 way down)
2. Press "Menu" button (center of remote - 1/2 way down)
3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver
4. Press "Enter" button (green letters)
5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver
6. Press "Enter" button (green letters)
7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver
8. Navigate from there
Hope it helps. It worked for us.
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag. press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
SOURCE: i need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
SOURCE: Yamaha RX-V750 AV receiver power problem
i had the same problem, only none of the above worked until someone told be to replace the ceramic cap .022 630v c405 on the sub board, and after this mine has worked fine since
