Question about OKIFAX 5400 Plain Paper LED Fax
How to clear memory full in okifax 5400 - OKIFAX 5400 Plain Paper LED Fax
Have a Okifax 5400 - changed toner and drum but still getting blank line down side of the page. Any way to fix?
clean the LED array with a soft cloth or tissue or the alcohol wipe that comes with new toner cartridges if you still have it. open the cover to expose the drum on the bottom side of cover is a black bar(LED ARRAY) as wide as the drum but about a half inch thick wipe the bottom side that will face the drum when the cover is closed
May 21, 2010 | Office Equipment & Supplies
Lg xenon says memory full. did a master clear and
it just means that your phone memory is full, you need to purchase a memory card to store other files
Jan 12, 2010 | LG Xenon GR500 Cell Phone
Our minolta fax 2600 is showing us we have a polygonal error
Not 100%, but I would say this referring to the laser unit.
Switch off/on...if no joy, it's probably an engineer job.
Jun 16, 2009 | OKIFAX 2600 Fax
When printing from the network. Alot of jumbled words.
It sounds like either a corrupt print driver installed on your pc or the incorrect one. Make sure you have the correct driver for your machine and download another one anyway in case your one is corrupt. Delete the one you are using first before installing the new one.
Jan 12, 2009 | OKIFAX 5400 Plain Paper LED Fax
Black Bars on the copy page
It sounds like you have a bad scanner unit.
Oct 27, 2008 | OKIFAX 5400 Plain Paper LED Fax
Check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
May 13, 2008 | OKIFAX 5650 Plain Paper LED Fax
'won't print date on photographs
the date is on the pictures in camera, right? that's a menu setting to encode the pictures with that information. otherwise, the printer won't see what's NOT there, right?
Mar 06, 2008 | OKIFAX 5400 Led Printer
Report Printing
Seeing old already printed report is your only hope i'm afraid,
once activity report is printed the memory is reset to allow it to remember next lot of fax's for you.
Oct 25, 2007 | OKIFAX 5400 Plain Paper LED Fax
OKIFAX 5400 Plain Paper LED Fax Logo
113 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
