Question about Lexmark X2500 All-In-One Printer
Scannig trying to scan, get a message to change display setting to 800x600 and 256 color. What does this mean
    Genius:
  • 3,587 Answers
That's on your display settings for your monitor..assuming you are on xp, go to start, settings/control panel/display settings/settings, and make adjustments there..
Posted on Apr 20, 2008
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
When I try to scan I get a message "your LCD list needs to be updated" how do I do this?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 21, 2011 | HP Computers & Internet
HP photosmart C6380 will scan to my USB external hard drive, but I can't get it to scan to my computer. It give the error message...Try starting scan from computer. Refer to documentation for details. ...
There might be some issues with scannig interface. To direcltly scan put paper in the scan bed and then open Paint then click on file from scanner or cameras.
Sep 08, 2010 | HP Photosmart C6380 All-In-One InkJet...
How do i turn off auto enter on my symbol ls3603mx scanner?
from manufacturers site take scan code sheet, you will just find there programming scan codes, one for start programming, another to terminate auto entry and third to terminate programming. that is correct procedure if scannig is automatically set in scanner, if scanning is in your database on other hand, you need to re-write that bit which insert your code to database/spreedsheet automatically and change it to manual, as i do not know which of these method you use, i cannot be more specific.
try scanner first! usually scanner is programmed on automatic.
Jul 20, 2010 | Symbol LS3603MX
TX IMAGE SET NOT TO DISPLAY
enable tx display at additional function button.
Aug 07, 2009 | Canon CLC 1120 Color Copier
My scanned color photos
  1. Check the automatic brightness and color settings by doing the following:
  2. Click Settings , click Scan Settings and Preferences , then click Preferences .
  3. Enable or disable (depending on their current state) the Automatically adjust exposure and/or Automatically adjust color settings.
  4. Click OK .
  5. Expand the scan preview by clicking the arrow on the right, and then adjust the Color settings prior to performing a final scan.
  6. Sometimes the scan will pick up reflected colors, try rotating the original 90 degrees and then scan again.
  7. All models except the PSC 1100 and 1200: If the scan still is not right, try resetting the all-in-one back to the factory default settings. Follow these steps to reset the defaults:
  8. Press Setup or Menu depending on your model.
  9. Press the Right Arrow or the Down Arrow until Maintenance or Tools appears in the Display, and then press Enter .
  10. Press the Right Arrow or the Down Arrow until Restore Factory Defaults appears in the Display, and then press Enter .
  11. Reset the all-in-one by unplugging the power cord and then plugging it back in. This will force the all-in-one to recalibrate
Good Luck
Aug 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Scan to folder
you need to set it up on your server why dont you scan to email talk to your it guys maybe the do not want people to scan to folder
Jul 11, 2008 | Canon CLC 1120 Color Copier
Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Jun 19, 2008 | Canon CLC 1120 Color Copier
Printer
if you are using windows XP
follow following instructions.
start
control panel
(make sure you are not on classic view)
appearance and themes
screen resolutions
left on botom put screen resolution on 800X600 or highre if your computer can handle it and color to highest
This should fix the problem.
Please rate this if this corrects your problem. Otherwis come back to me
Apr 20, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X2500 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
