Question about Maytag M6Y12F2A Air Conditioner
NO FAN JUST HUMS WHEN ITS TURNED ON SOUNDS LIKE FAN MOTOR IS SIEZED UP?
  • Maytag Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Washer stopped working with low humming noise
Belt may have broken or come off, or idler seized or main support bearing siezed or even motor bushings may have seized. Best access is from above to check.
If you can spin the drum with ease from the inside, the belt broke or is off. If it will not turn, the motor bushings may have siezed, or the main bearing siezed.
Apr 12, 2012 | Kenmore HE2 Plus Front Load Washer
Maytag air conditioner turns on but fan does not blow. When I put the unit to fan only, I hear the hum of the fan, but no air coming out.
Either the capcitor has gone bad for the fan motor or the motor has siezed up or gone bad... you cold try to replace the cap. first and move on from there....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
heatman101
Aug 17, 2010 | Maytag M7D24E7A Air Conditioner
CREDA OVEN FAN NOT WORKING OVEN BARELY HEATING
As a first port of call, you can remove the fan by removing the inner back panel (4 screws) and taking the fan blade off (anti clockwise screw) The drop the fan out through the back of the cooker. If you apply WD40 to the two bearings you may get the fan going again. Otherwise you'll have to replace it.
Sep 29, 2009 | Creda C361E Electric Kitchen Range
I thought i smelled the ordor of burnt wire coming from somewhere in the house, which I could not figure out where it was coming from. I tried to regulate the therostat and found the a/c would not come on....
sounds like a siezed up blower motor inside your furnace if you were running your air conditioner with out the blower motor it will turn everything into a block of ice at your indoor coil you need to let this thaw out
i would recommend calling a heating an air conditioning company
Aug 04, 2009 | Heating & Cooling
Motor outside is humming like it on but the fan isn't turning
Sounds like the run capacitor is bad or the bearings or siezing up. Turn the power off to the unit, then spin the fan blade to see if it spins freely, if it does then it's probably the capacitor.
Jun 22, 2009 | Heating & Cooling
Motor is siezed
Usually this means dirt/dust/debris has gotten into the bearings. Needs a lube job.
Dec 15, 2007 | Patton U2-1487 Floor / Box Fan
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag M6Y12F2A Air Conditioner Logo
136 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
