Question about Cfm FlowPro Industrial Pedestal Fan - 8500 , 1/4 HP
HOW TO ASSEMBLE AN 18" PEDASTIL FAN
HOW TO ASSEMBLE AN 18" HIGH VELOCITY FAN UNIQUEWARE MODEL V/2738
  • play_reality
    play_reality Jun 22, 2012
    I did everything right, although the instructions are not clear nor helpful. Plugged it in and it does not work!
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
How to locate fuse for comfort zone fan?
Probably doesn't have one, usually the motor has thermal protection so no fuse required.
Apr 23, 2014 | Comfort Zone CZHV18B 18 Inch High Velocity...
Polar Aire 20 In. 3-Speed High-Velocity Floor Fan on off switch wiring
i need an on/off switch for my utilitech 20" high velocity floor fan model # LF-20MCA
Mar 26, 2012 | Dryers
Since Lakewood doesn't make fans any longer, any idea where I could pick up a couple of their 9-inch high velocity fans (new or used)?
Hi randy r metc...
I found one 9" High Velocity fan on ebay, it is new at a cost of $19.99 and free shipping.
Please take time to rate me
To see the fan go to the following webpage
http://www.ebay.com/itm/Lakewood-9-High-Velocity-Fan-1016-/320745163838?pt=LH_DefaultDomain_0&hash=item4aade6cc3e
Aug 18, 2011 | Lakewood High Velocity Fan 9 Inch
Fan vibrates real bad. Needs a new blade. 18 inch floor fan. Blade is weak and bends easily.
Stick a small weight to the end of one of the fan blades with some sellotape , run the fan , if the noise gets worse transfer the weight to another blade.
When the fan is running quietly go to the blade opposite to the one with the weight on and drill out a 10mm hole in the material.
Take the weight off and check for balance if it is still out drill another smaller hole in the blade till you get a balance
Drill the holes a the tip of the blade so that you get the best effect from the removal of material
This will save you buying a new blade
Oct 09, 2009 | Outdoor Concepts 18-Inch High Velocity...
Fan does not accept fastest velocity
Contact the Manufacturer or an electrictian, it could be a vault in the fan itself.
Sep 18, 2009 | Hampton Bay 24002 Ceiling Fan
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
Aug 01, 2009 | Lasko High Velocity Space-Saving Blower...
Where can i get a replacement 3 blade propellar? for a high velocity air circulator fan?
www.thefind.com/.../browse-high-velocity-industrial-fan use this site
Jul 19, 2009 | Bionaire Dryers
Cfm FlowPro Industrial Pedestal Fan - 8500 , 1/4 HP Logo
402 people viewed this question
Top Cfm Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
 Russ Hill
Russ Hill
Are you a Cfm Dryer Expert? Answer questions, earn points and help others
