Question about Sony Ericsson W910i Cellular Phone
Some of the main buttons are not working. Eg. Call and end buttons
Posted on Jul 27, 2010
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
Viewsonic TV N3735w, frozen on menu. Buttons do not work on TV. Pushing buttons on remote: "registers" on TV for a second but always returns to menu, regardless of button pushed. Cannot...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 25, 2017 | Televison & Video
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Televison & Video
I did not recieve any software or instructions on how to install my external hard drive model WD10000H1Q-00
Hi, perhaps this will help, I have just bought a WD Elements  hard drive,with install instructions. Step 1.Plug the usb cable into your pc and the other end into the hard drive. Step 2.Plug the power adaptor into the hard drive and then the other end into the mains. Step 3.Now switch on the main power.Your pc will now tell you it has "Found New Hardware" and will then show under" Hard Drive Disks" your hard driveand asign it a name and a letter eg.Elements(L:)
Regards Bill
Nov 26, 2009 | Western Digital My Book Home Edition 500...
Cealing fan wiring problem
Hi, try this.
The pull chain has four wires, L, 1, 2, 3. Connect '3' to the main black (hot) wire entering the fan. Connect 'L' to the red wire on the reverse switch. connect '1' to the lowest uF, eg ( 1.5 uF ). Connect '2' to the next uF, eg ( 3uF ). The other end of the capacitor has to be connected to the neutral wire, ( black with pink or white). If you have a VOM tester, check that pull switch is working properly, eg when the switch is on the Hi speed position, you should get a continuety reading on all the ends of the switch,
Apr 05, 2009 | Westinghouse Fans Indoor Ceiling Fans
Technika tt-16 universal remote control codes for a beko tv
Auto code search
Nov 10, 2008 | RCA Universal Remote Control
Need code or code search proceedure for Advent RC-S11-0A remote
Most Universals work similar for code search, try this on yours. [list] [1] Manually turn on the device (eg TV) [2] Press & hold Code button until indicator light stays on (or blinks on some) release Search button. [3] Press & release device button (eg TV). The indicator should blink off. [4] Point Remote at device (eg TV). [5] Press the Power button on/off down until the device turns off. [6] Press the ENTER button or OK button to save the code as soon as the device shuts off. (Suggest you have a finger on it for fast response.) Hope this works for you.
May 12, 2007 | Recoton Advent Advent RCS110A Remote...
Sony Ericsson W910i Cellular Phone Logo
724 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
