Toshiba: 50hp95 Symptom: Powers-up as soon as ac is applied, cannot power off, green lite flashes three times and in the lower left corner it reads now booting. Customer controls do not function. The original problem was a dead set. I replaced the power suuply board. Also, the top fans run at power-on, but the bottom fans do not and i do see back lite.
    President:
  • 1,099 Answers
The power supply you brought may be compactable with other boards in the television or may be power supply board is faulty. you can try
websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck, hope this work..........
Posted on Jul 08, 2010
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Tip
Toshiba 50HP95 Input Lock Reset
Toshiba 50HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tip
Toshiba 50HP95 VChip Reset
Toshiba 50HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Tip
Toshiba 50HP95 Manual Download
Would you like to review the features of the Toshiba 50HP95 Plasma TV ?
Have you lost your Toshiba 50HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 50HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 50HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
Tip
My DS has power, but my screens are blank!
HELLO!!
I've seen countless amounts of Nintendo DSlites with this generic problem. If you have experience opening up electronics, you will find this to be a VERY easy fix. A fix that'll make you happy you didn't blow money on having a professional repair it. It doesn't take a professional to repair this. Continue reading :)
PROBLEM: A Nintedo DSLite that powers up, but doesn't display video. Here's what your situation should look like
  1. Nintendo DS has power. (power indicator light is either green or red.)
  2. Both screens (upper and lower) are both black/blank
What causes this problem?
- Your Wireless wifi board on your nintendo DS has gone bad.
How do we fix this problem?
- Simple, replace it :)
Here's what it looks like...
This is where it goes... (top left corner)
Easy Easy Fix...
If it helps, please let me know!
Great!
on Jan 01, 2010 | Nintendo DS Lite Console
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
