I have an akai ac-gs24hrc reverse cycle air conditioner. Is there any manual parts list or service available from akai for this product
Coldcut
  • 1554 Answers
SOURCE: No service support for mitshubishi air conditioner
That is normal for a exporter to not provide warranty unless you ship it back.
Posted on Apr 01, 2008
  • 143 Answers
SOURCE: my reverse cycle air conditioner
Sounds like an electrical problem. The only part that is supposed to work during heat, but not cooling, is the reversing valve. That could be physically stuck.
All other ways to cause this problem are electrical. You will be getting in ther with your volt meter to solve this problem.
Posted on Jul 27, 2008
SOURCE: Owner's manual for a Hampton Bay HBTE120 Air Conditioner?
http://www.appliancefactoryparts.com/content/pdfs/118255.pdf
this is the pdf of the manual for that particular model of a/c.
hope that helps.
Posted on Aug 29, 2008
SOURCE: manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Posted on Sep 06, 2008
  • 2692 Answers
SOURCE: air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Posted on May 10, 2009
ArcticPro portable air conditioner FAAC7. Now need window kit window.Tried some web sites for parts but no luck.i
Your Fridge Electric air conditioner probably was manufactured somewhere in Asia and imported by the distributor in Canton, Ohio. There may be no support available.
Jul 15, 2014 | Arcticpro Ypc-07c Faac7 Portable Air...
Why did my ac quiet blowng heat
Check the controls, this unit most likely a reverse cycle air conditioner. It can be set to cooling or to heating. The conpressor is reversed to heat or running normally to cool.
If it is not then the compressor is not working and it is just blowing room temperature air.
Apr 03, 2012 | LG Heat cool Window Air Conditioner
I have a 1993 Chevy S-10 4.3L automatic. The heat won't shut off. It pours out regardless of the position of the climate controls. Coolant level and condition good. AC would work but. Thanks.
#46-12-03: AIR CONDITIONER BLOWS WARM AIR (REPLACE A/C DELAY RELAY) - (Apr 7, 1994) 999999995.gif REVISION: 04/14/94
THIS BULLETIN IS BEING REVISED TO CORRECT THE TRANSMISSION LISTED IN THE MODELS. ----------------------------------------------------------------------
SUBJECT: AIR CONDITIONER BLOWS WARM AIR (REPLACE A/C DELAY RELAY)
MODELS: 1994 CHEVROLET AND GMC TRUCK S/T PICKUP WITH 4.3 ENGINE (VIN Z - RPO LB4), 4L60E TRANSMISSION (M30) AND AIR CONDITIONER/MANUAL CONTROLS (C60); OR 4.3 ENGINE (VIN W - RPO L35) AND A/C (C60)
BUILT BEFORE THE FOLLOWING VIN BREAKPOINTS:
PLANT DIVISION VIN LINDEN GMC RK501034 SHREVEPORT GMC R8501199 SHREVEPORT CHEVROLET R8105893 LINDEN CHEVROLET RK103097
CONDITION:
SOME OWNERS MAY EXPERIENCE A CONDITION WHERE THE AIR CONDITIONER IS TURNED ON AND DELIVERS ONLY WARM AIR.
CAUSE:
THE AIR CONDITIONER COMPRESSOR MAY DELAY LONGER THAN THE "ORIGINAL DESIGN" INTENDED 12 SECONDS, OR MAY NOT ENGAGE, DUE TO THE POSSIBLE MALFUNCTION OF THE COMPRESSOR DELAY RELAY.
CORRECTION:
TRUCKS BUILT BEFORE THE VIN BREAKPOINTS LISTED ABOVE MAY NEED A NEW AIR CONDITIONER DELAY RELAY. REPLACE ONLY WITH 15990540 AIR CONDITIONER COMPRESSOR DELAY RELAY. SPECIFIED PROCEDURE IN SERVICE MANUAL NATP 9429, PAGE 1B-59. TEST AIR CONDITIONER OPERATION FOR DELIVERY OF COOL AIR.
NOTE:TO TEST FOR PROPER OPERATION, PUT THE A/C CONTROL ON THE "OFF" POSITION, START THE ENGINE, THEN PLACE THE A/C CONTROL IN THE "ON" POSITION. THIS SEQUENCE WILL PROVIDE IMMEDIATE ENGAGEMENT OF THE AIR CONDITIONER COMPRESSOR. WHEN THE ENGINE IS STARTED WITH THE A/C CONTROL ALREADY "ON", THERE WILL BE A NORMAL 15.0 SECOND DELAY FOR THE AIR CONDITIONER TO ENGAGE.
SERVICE PARTS INFORMATION:
P/N DESCRIPTION QTY
15990540 A/C COMPRESSOR DELAY RELAY 1
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
Jul 29, 2011 | 1994 Chevrolet S-10 Blazer
Danby AC DPAC7099. I need an exploded view or parts list. I can't find it anywhere. Basically what I need is the float assy..
Here is a link to your Owners Manual, in case you have misplaced yours, as well as a contact number for Danby Customer Service, where you can also purchase the part.
http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf
Customer Service: 800-263-2629
Hope this helps you get the float assembly you need.
May 09, 2011 | Danby DPAC7099 Air Conditioner
Cools fine for about 30 minutes then turns off but wont come back on. it has to sit about 2 hours then the cycle continues.
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t finCOLEMAN R.V. PRODUCTS
d the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 06, 2010 | Coleman Mach III Air Conditioner
Okay I got a reply for help on my fedder air conditioner, but for some reason I never found the owners manual where I was sent to so Thank You for your help and now I will send the Model #out so maybe...
OK, now with the model number you provided, I can determine that it's an older model and the manual is no longer available online. The part number for the manual should be #CRC23230258N013
This supplier states to email them for price and availability, scroll down a bit and you'll see the manual in the list of parts available.
http://www.appliancefactoryparts.com/humidifiers/fedders/a6d24e7a-k.html
Here's a link with the contact info for Fedders you can give them a call and see if they can provide you with one. I've spent quite a bit of time searching all possible sources for the out-of-print manual and came up empty, although I did find a couple of shops that once had them, they've run out as well.
http://www.fedders.com/contactus.asp
Hope this helps, and best of luck in finding a manual for your AC.
Aug 07, 2009 | Fedders Appliance Air Conditioner Wall
Manual for Akai reverse cycle airconditioner remote control
Jun 08, 2008 | Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
