Question about E-Machines T6216 (827103077834) PC Desktop
No Display I turn on the computer, appears to be powering up, but there is no display. Even accessing the computer remotely results in no display appearing.
    Master:
  • 515 Answers
Display set to too dark? Tried another monitor, safe mode or another graphic card? If safe mode works, then you might need to update the driver of your graphic card. What setting do you use for the remote connection?
Posted on Jul 09, 2010
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
What causes laptos to not show display despite showing that they have switched on?
Step 1:
The display on your laptop is the interface through which you interact with and control your computer. If it is not working, your laptop will become virtually impossible to use. A laptop is a computer, and like all computers is subject to both hardware and software problems that may affect the display. Before taking your laptop in for repair or getting rid of it, you should first check the display yourself to see if it needs to be replaced.
Check the laptop's battery and power cord. If the laptop is out of power, the display will not work. This usually happens if the power cord is unplugged and you were unknowingly running your laptop on battery power. Check to make sure the power cord is plugged in and that the laptop has power. Many laptops also turn off the display if it is being powered by its battery after a period of nonuse. Touching any key will usually turn the display back on if the battery is not drained. Restart your computer. If a software program is stuck or malfunctioning, it may cause your display to stop functioning. Press and hold the "Power" button on your laptop to reboot your computer. If the problem was a malfunctioning program, the display will turn on after the computer restarts. Check the brightness level of the display. If the level is too low, the screen will appear dark. The brightness controls are usually located on two function keys, such as "F9" and "F10." Look for sun or light icons on the keys. Press the key with the larger icon to increase the brightness level. Alternatively, on some laptops hold the "Fn" key while simultaneously pressing the "Up Arrow" key to increase the screen brightness. Check the display closed switch. Many laptops have a small button that senses when the LCD screen is closed and puts the laptop in sleep or hibernation mode. If the switch gets clogged with dirt, it may get stuck in the closed position. This will result in dark display even when the lid is open. The switch is usually located near the hinges of the lid. Spray the switch with a can of compressed air to loosen the dirt so that it will resume its normal operation. Plug an external monitor into your laptop. If the problem is not software related, the external monitor will display the laptop's screen. Connect the monitor by plugging the cable into the VGA, HDMI or DVI port on the laptop. Press and hold the "Fn" key while simultaneously pressing the "F8" key. The video output will be directed to the external monitor if there is a hardware problem.
b>
Feb 21, 2013 | Toshiba Satellite Computers & Internet
Lcd screen not working
Step 1:
Feb 20, 2013 | Computers & Internet
Tower turns on but nothing appears on monitor
You need to follow the easy steps and get rid of it
1. Make sure your display (moniter, CRT, LCD, screen, whatever you prefer to call it) is plugged into a wall outlet or power strip and powered on. Also ensure that it is securely plugged into the back or bottom of your display. Many displays do not have removable power cords, making them more prone to shorts and other damage. Check your cable to make sure it isn't damaged.
2. Make sure the power strip or wall outlet that your display is plugged into are functioning by plugging another electrical device, such as a lamp, into it and switching it on.
3. Check the connection between your computer and your display. Make sure that it is completely plugged into both as well as fastened with the attached screws.
5. To double-check any possible cable problems, if at all possible, swap out the screen's power cord and the cable connecting your computer to your display.
6. Swapping out your display is also a good way of narrowing down the problem. If you get the same result with a different display, then you can be near positive the problem is something in your computer. If switching displays fixes it, then the culprit is a faulty display.
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the monitor but in the computer.
Read more: http://www.brighthub.com/computing/hardware/articles/12648.aspx#ixzz0s9UQmWub
Please rate me if this solution works for you
Thanks......Have a great time
Jun 26, 2010 | Gateway 504GR PC Desktop
SONY BRAVIA KDL40D3100
These new LCD televisions have a number of display modes, some which magnify and crop the video. You must have one of the magnification modes on, something called "wide zoom". As a result, some of the text is getting cropped because the whole picture is actually cropped (you just didn't notice). Use your remote and try changing the display mode. You should be able to get to "normal" and then basic wide (not wide zoom). Try it out. :-)
Dec 14, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
ADI A905, No Display, but appears to get signal
I have the same problems as you. I found the only fix is to physically unplug the monitor from the wall outlet, and then it plug back in. Sounds like an internal design flaw.
Oct 02, 2007 | ADI Corporation MicroScan A905 Black 19...
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
E-Machines T6216 (827103077834) PC Desktop Logo
132 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
