Question about Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator
My power went out and since it was restored my fridge won't come.
During a storm 2 days ago, we lost power. Since the power was restored our fridge will not come on. we have lights inside but it won't cool or freeze anything, the ice machine or water will not work.
  • 3 Answers
IIRC your refrigerator has an electronic control in the front face of the freezer door. Both sides have 3 buttons in a vertical column. Is there any sign of life on this control panel (IE do you see the stack of horizontal green bars lit up and does pushing the "freeze" or "fridge" button change them)? If not, then the most likely scenario is that you had a big power surge when the AC voltage came back and it blew out your control panel. If you can install an adequatley rated surge protector in the power line for your refrigerator you can prevent this from happening again.
Posted on Sep 24, 2010
2008 Highlander will not start. Makes a ticking noise when pressing keyless start
Immobiliser ?
Try this thread it may help - http://www.helpowl.com/a/Toyota/2008-Highlander/Research/5115?search=2008%20toyota%20highlander%20vsc%20check%20engine%20light
Mar 19, 2014 | 2005 Toyota Highlander
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
My 1998 jaguars xj8L stopped starting after the rain storm 2 days ago. I did not drive the car during the storm and the car did not flood. I got a new battery and new spark plugs. The car tries to turn...
as crazy as this sound, Was there lighting during the storm? my car was parked under a tree that got hit by lighting and had to replace the ecu.
Apr 07, 2012 | 1996 Jaguar Vanden Plas
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
We had a thunder storm a few days ago and that we lost power and that the pc shut down by it self so the next day we try to turn on the pc so it won't turn on please can you help us
Make sure that all the plugs are plugged in. Try a different outlet, if it's plugged into a surge protector make sure that it didn't trip. Or if is plugged into a regular power strip press the reset button on the side of the strip. If that doesn't work there usually is a fuse inside the PC that might have blown.
Jun 05, 2011 | HP Pavilion a6700y PC Desktop
I have a AT@T Model No. E5908, 5.8GHz Corded/Cordless Telephone/Answering System that has always worked perfectly until a bad lightning storm hit a couple of days ago which caused the power to go off. The...
I hate to be the bearer of bad news, but there is no reset on the phone system, and it's a near certainty that a power surge during the storm "fried" the sensitive circuitry in your phone. The same thing happened to me a couple of years ago and I ended up replacing my phone system. A corded phone in the house at the same time lost its ringer during our storm. To this day it still works fine, but will not ring. While you cannot save your present equipment, it's possible to protect your replacement by installing a phone line surge protector (available at just about any store that sells phones or computers) and a whole house surge protector that you install at the main outside breaker box (you'll need to search the web for that one. Look for a SYCOM surge protector).
Mar 30, 2011 | AT&T Lands Phones
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator Logo
295 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
