Question about JVC AV-48WP30 48" Rear Projection Television
Have message bulb needs replacing but is that what is making the screen greenish all the coloring is off looks like martians on tv Is it being caused by the bad bulb? I want to replace it but if it is not caused by the bulb is it worth my time?
    Problem Solver:
  • 8 Answers
Do you know if your tv is DLP or Liquid Crystal over Silicon, or just LCD, if it is Liquid crystal the green one could be failing, if it is DLP you may need a color wheel. I doubt a new bulb will fix that problem
Posted on Jul 08, 2010
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
We cleaned the lenes and put new bulb in ,put the tv back together and the picture to colors like voilet color and a bright yellow took it apart 3 times..dont know what else is wrong
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 06, 2011 | Philips 55PL9524 55" Rear Projection...
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Green tin to screen
Go to the menu on your tv and look for the color balance controls, You should be able to adjust the color to make it better.
Jan 22, 2010 | ViewSonic VA1930WM LCD Monitor
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
We also have a greenish tint. We put a new bulb in because the box that said bulb needed replacing came up. We reset the tv but its still green. we have tried to adjust colors, temperature adjustment and...
Your "light engine has possibly gone down on you, did you replace just the bulb it's self or the complete bulb assembly? If you pulled out light assembly and replace just the bulb then repalce light assembly, if you repalced the whole light socket assembly and still have greenish color the you have a "light engine problem". Seek repair tech.
Oct 01, 2009 | Sony KDS-55A2020 55" Television
I have a Sony KDS 55A TV.
Please check color temperature adjustment in menu and also check white balance adjustment.
Jul 23, 2009 | Sony KDS-55A2020 55" Television
Uneven Color on JVC Projection TV
hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Sep 01, 2008 | JVC HD-52Z575 52" Rear Projection...
TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Jul 29, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
JVC AV-48WP30 48" Rear Projection Television Logo
103 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
