Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Lights come on fan blows air thermostat is on. but only hot air come out i just bought a 2005 rv all the appliances look bran new so does the ice box can you tell me most likely what the problem is chef magic is the brand name
    Problem Solver:
  • 9 Answers
Say nothing is yet solved... pls do check.. temp switch attached to the evap fins .. it may malfunction...though i assume that you heard and confirmed that the compressor is running fine ..and condenser is producing hot temps.. god speed bro..
Posted on Sep 09, 2010
A/c will not continue to cool.. Starts fine, runs fine.. but shuts down cooling ( comp shuts off but fan still runs) after anywhere from 5 min to multiple hours. No circuit breakers or fuses blow. CAN...
One amateur test is to place your hand on the compressor and see if it
is too hot to hold your hand on it. You may have a restricted condenser coil
If it is too hot then the condenser coil is restricted inside the unit
if not be sure and clean condenser coils with good coil cleaner.
You can put a fan on the compressor and see if it runs for another test to confirm it
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 22, 2010 | Dometic Rooftop RV Air Conditioner
My air conditioner keeps icing up and the flow is then reduced and cooling is diminished. I was recently in a very hot area and the AC was working very hard. I'm in a more reosonable temperature now but...
Check the filters and make sure the coils are clean first. Then make sure both fans are running, the evaporator fan and condenser fan. If all of that is ok then you need to get the refrigerant charge checked.
Jul 23, 2010 | Dometic Rooftop RV Air Conditioner
Freezer does not freeze things, ice cream is liquid
Check:
(You may need to remove the back cover for next two steps)
* Is the fan in the back of the appliance working? If not, use a fan a blow some air in the condenser.
* Is the condenser clean? remove dust, lint and other particles.
* Is the appliance installed in the garage, a hot location, or closed to the range? You may need to place the fridge in a better location. Some kits are available if the appliance needs to be placed in a hot location.
* Is the thermostat low? Try to "increase" the temperature to "colder"
* Is the fridge door closing properly? Check the seal around the door if it closes perfectly.
If nothing of above works, it may be caused by:
* Broken thermostat.
* Failure on the sealed system
Good luck.
Sep 01, 2009 | LG LSC26905TT Side by Side Refrigerator
We got home from work yesterday and the refrigerator was HOT inside.
How to check stuff
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 10, 2009 | GE Profile PCF25PGW Side by Side...
Blowing hot air. Compressor not kicking on. Where
Possibly three things, either a thermostat problem, starter relay/capictor, or a bad overload protector not closing after an overload. The starter relay should be behind a black box located on the side of the compressor.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
Furnace has a mind of its own
If your thermostat no longer controls your furnace possibly could be the control board in the furnace or a shorted fan relay.
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
RV ice box freezes everything
if it have a timer board change it
Mar 31, 2009 | Dometic Refrigerators
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
63 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
