Question about Frigidaire GLRS237ZA Side by Side Refrigerator
The ice dispencer is always running out of ice there is a setting for making extra ice for hot day but lost my manual
  • 4,070 Answers
To increase ice production for special occasions, such as parties, push the Touch Pad _ for
3-5 seconds to activate this feature. A green light will appear above the Touch Pad. Push the
Touch Pad _ again for 3-5 seconds to deactivate.
Here is a link to your manual. http://www.managemylife.com/mmh/owner_manuals/4709/FRIGIDAIRE-Side-by-Side-Refrigerator-L0302088?brand_name_search=GLRS237ZAW7+FRIGIDAIRE
Posted on Jul 08, 2010
Freezer too warm
First off, how old is the unit? Without knowing, my advice, and what has worked many times, is to unplug the unit, and turn it upside down. Thats right. Upside down. May take a couple or few people, depending on the weight. What this does, is to have the refrigerant begin running back to the top of the unit. Sometimes it settles in the bottom, and has to have extra help to start moving properly again. If, after about 6 to 24 hours it doesn't seem to have helped, it could be that you have lost the fluid, but that doesn't seem very likely. If you had, it would run consistently at the same warm temperature. If it helps, you may want to repeat the procedure to insure that it is completely free flowing. Cheap fix, if it fixes things. Good luck.
Nov 15, 2012 | GE Monogram ZFSB23DRSS 36" Monogram...
I have a side by side Fridge. Model TPX24PRBBWW
turn the controls to factory settings and give it a couple of days, if it is too cold the ice can not release!!
Nov 15, 2009 | Refrigerators
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser gives crushed ice only, no ice cubes
The dispencer my be plugged, take it out and let it thaw for a day and then clean and replace it.
Aug 16, 2009 | Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Washer is leaving blue stains on clothes after washing.
ok kenna ,,open lid and grasp the fabric dispencer from the top and pull straight up,,it well come off,,,next run it under hot water for a few minutes,,now get some bleach and fill dispencer and let soak over night than flush again with hot water,,that should free it..to get your manual go to servicematters.com..im onthejob
Oct 19, 2008 | Whirlpool LSR7333 Top Load Washer
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
