Question about Amana NED7200TW Electric Dryer
Error code E5
I have replaced thermoistor and still shows error code e5???
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: WE have an e5 error
This problem indicates to Heater Temperature Control the thermistor which senses the heat has shorted out and needs replacing so the dryer can operate normally.
You can get the part on the link below.
http://www.appliancepartspros.com/part_details.aspx?part_id=4045617
Posted on Jan 07, 2011
Macmarkus
  • 2605 Answers
SOURCE: I have replaced the thermistor
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Amana dryer, (as you may or may not know this model is built by Samsung) and it is displaying a e5 error (actually looks like a e5 error, but it is indeed t5 but that's because of the digital display)...it is actually a "temperature sensor" error, hence the "ts".
As described in the service manual from Maytag...
"tS" Dryer Thermistor Short Sensed - The Thermistor resistance is very low.
Check for:
Clogged lint screen. (remove and wash under hot water & mild soap...a old toothbrush works well for scrubbing)
Restricted vent system.
Check Thermistor resistance...10000 ohms @ 77°F/25°C
If you've replaced the thermistor already, that leaves either poor air flow due to clogged lint screen or clogged exhaust somewhere else along the line. Here's what I would suggest you try. Remove the lint filter (clean it as mentioned above) and unfasten the vent from the back/side of the dryer, whatever the case on your machine. Run it through a cycle without a load and post back with the results.
I can send you the service manual if you think it may help you move forward,(It says Maytag, but those are Amana/Samsung as well) but you'd need to provide an email address for me to attach it to. It is a "pdf" and 9.9mb in size.
I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Jul 30, 2011
E5 show on my screen cannot sew keep on peeping
singer sewing machine error code e5 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your singer sewing machine error code e5 question. Get free help, tips & support from top experts on ... Singer 3116 Simple. 887 Questions ...
Sep 20, 2015 | Singer 3116 Simple
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
Showing error E5
E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
Jul 29, 2014 | Bosch WAB28060GB Maxx White 600 mm Washer...
Error code e5
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
Jul 27, 2014 | Electrolux Refrigerators
E5 error
The error code E5 shows that your colour cartridge is finished and the printer is telling
Read more: How to clear error code e5 - What does it mean when my mp210 canon printer has the alarm on :: Extreme Cow Answers at http://www.extremecow.com/How_to_clear_error_code_e5-qna9448.html
Hope it helps
--N
Apr 02, 2014 | Canon PIXMA MP210 Photo All-In-One Printer
What is an error code E5 mean?
Error code 5 means : Required temperature not reached.
Causes/Trubleshooting
Thermoblock has blown - replace thermoblock.
Power electronics is defective - replace the triacs of the power board or the whole power board.
Attention - determine resistance value of the Thermoblock to avoid subsequent errors.
Jul 09, 2013 | Jura Capresso Jura-Capresso J6
Thermostat showing error code E5
E5 Outdoor activation of compressor over heatprotection or motor lock
1.Condenser block-Clean it. 2.Less rpm of motor-replace capacitor. 3. Motor Lock-replace motor.
Dec 31, 2010 | Carrier TSTATHPP 7-Day Programmable...
Error code e5?
Good day sir, E5 indicates that the electrics/fuse wire has burnt out in one of your cartridges. Replace appropriate cartridge.
Jul 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Amana NED7200TW Electric Dryer Logo
244 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
