Question about Panasonic PT-52LCX66 Projection Television
When i turn on the set i get an onscreen message that says replace lamp did that worked for a month same thing another lamp another month another lamp another month. i talked to a repair person who said he had 4 just like it at his shop.
  • loren835 Jul 08, 2010
    I should add if i plug and unplug the power cord and
    turn on and off the set multiple times i can get it to
    turn on. If I get it on it will play as long as I want.
    But if I turn it off at any time the same problem occurs.
    Problem Solver:
  • 8 Answers
A cooling fan could have failed or is clogged with dust or the ballast may be over driving the lamp. If the tv is in warranty or just outside of warranty call Panasonic directly. also make shure the cooling vents have space for air flow
Posted on Jul 08, 2010
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How to reset the lamp timer for Sony Projector vpl-px32
      Instructions
        • 1 Turn on your Sony projector after replacing the lamp.
        • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
      • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Jul 07, 2014 | Panasonic PT-44LCX65 Television
    The batteries keep going flat in my HP remote keyboard. The original batteries lasted about 12 months .When a notice appeared on the screen saying the battery was low i replaced them now they only last 2...
    you might want to try quality batteries. When you replace the batteries let the keyboard set with no batteries for e.g. 5 minutes so that it "registers" that the batteries have been replaced. Maby disable the onscreen message and just use the keyboard untill it stops working :-)
    Regards.
    Apr 02, 2011 | Compaq Keyboard
    A message appears when the set (LCD) is turned on whichstates that the lamp should be replaced but it is workning. Replaced the lamp 11 months ago and it has a 1 year warranty. What is the purpose of the...
    that lamp timers are only there to give you an idea that the lamp may fail soon. the tv will count to a certain number of hours and then give the message on screen. most tvs the number will be around 4000hours or so. i suggest using the tv until the lamp fails you may change a lamp that has many many many more hours when you dont need to. there is a timer that you can reset if you consult your owners manual so the message will not show up any longer.
    Dec 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
    Lamp life indicator reset
    Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
    Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
    Optoma ep716
    Go to the onscreen menu and check lamp settings. Disable auto shut-off.
    Nov 09, 2008 | Optoma EP716 Multimedia Projector
    Lamp automatically turns off
    Hi there
    Did you reset the lamp timer ?
    Jan 24, 2008 | InFocus IN72 Multimedia Projector
    Problems with Mitsubishi WD-52525
    When you replace these laps on these TV's they have an internal clock to countdown the lamp usage. After installing the new lamp the TV asked you if you replaced the lamp and you should answer yes. If not its going to ask again. First thing is go through the motion of replacing the lamp take the lamp out etc. then place it back in the set and turn it back on. Follow the on screen instructions and that should reset the lamp timer.
    Jan 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
    You have to follow the manual reset instructions in the user manual. Something like press and hold both brightness buttons for 10 seconds. See the manual.
    Jan 01, 2008 | InFocus ScreenPlay 7205 Multimedia...
    Panasonic PT-52LCX66 Projection Television Logo
    172 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
