Question about VeriFone Omni 3200 Printer
My co-worker changed the printer paper and now it is not printing
    Problem Solver:
  • 5 Answers
The thermal paper is upside down
Posted on Dec 14, 2011
Hi I am having a problem with our business HP LaserKet 424n printer; when we print anything out it seems to make a noise that it normally doesnt make, and our paper ends up looking smeared to the point ink...
Take print out of configuration page(menu-information-configuration page), chech the maintenance kit interval 2,25,000 crossed?
YES... replace maintenance kit & Swing plate assm..
NO... check fuser sleeve surface arrested with toner?...Replace fuser...
Sep 04, 2011 | HP LaserJet 4240n Printer
It's printing in landscape form and I can't figure out how to get it to print back in portrait form. A co-worker of mine screwed up the machine!
Hi
sometimes just some of the printer drivers are with "bugs" like this one.
If you are using Win 7 or newer ver. please don't let the operation system to install drivers for this printer. Download drivers from www.hp.com and install it manual. Try different drivers. I'm sure that this will help to prevent "landscaping"pocvnqve445ajvwaaaaasuvork5cyii=
Good luck.
Pifonski
Apr 02, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
Printer making a knocking noise
a co-worker had the same problem it looked dirty inside so i took some compressed air to it works great!!!
Oct 12, 2009 | Dell 1720dn Laser Printer
MFC-7840w keeps saying "toner life end"
After I figured this out, it was quite easy to resolve. Remove the toner cartridge from the drum cartridge. Remove the black plastic cover on the left side of the toner cartridge (3 Phillips screws). There is a "flag", which is a small plastic tab on the outer side set to the right at about 2 o'clock. Turn the gears until you fully reset the tab going counterclockwise to the 10 o'clock position (fully to the left). Reinstall the small black cover and the three phillips screws. And the idea to install black electrical tape over the small clear plastic windows on both sides is also a good idea to prevent the early and false message that the cartridge is empty. Make sure you do not allow that tape to get into the gears.
Sep 25, 2009 | Brother MFC 7840W Printer
Printed, now not printing nothing changed...
Try shutting down your computer and restart Make sure the printer is on before restarting the system
Have you cancelled the print que?
May 04, 2009 | HP LaserJet 2420 Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Print smear
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Oct 15, 2008 | HP LaserJet 1100 Printer
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Paper Size Error
Hi there check that the printer properties have not been changed.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on printer icon
  • Select Printing preferences
  • Check that the paper size matches that you have got in the tray
  • OK and exit and test
If the above doesn't work try the following
  • Open MS Word
  • Open the document that you are having problems with
  • Click File
  • Select Page Setup
  • Check that Paper Size is correct
  • OK close and test.
This is normally a driver issue as the paper tray on the printer doesn't know what size paper is in it until you tell it from the driver.
Hope this works for you
Thanks J
Dec 27, 2007 | HP DeskJet 5650 InkJet Printer
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
