Question about Kenmore Oasis HE 27062 Top Load Washer
"F1" trouble code
I have a kenmore 27062 he top load machie that keepsgiving an "F1" code. What is it and how do I fix it?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
F1 appears on my oasis washer what is f1?
F1 is a base code you need you put unit in to service mode to find out the fault code, to put it in service mode press 2 rinse on for 4 sec. off 4 sec. on 4 sec. off 4 sec. on for sec. and that code will tell you what is wrong if it is a f-68 code it will need a new main control. sears will replaced it if you call them with a model and serial # for free in most cases
Sep 27, 2010 | Kenmore Oasis HE 27062 Top Load Washer
The washer says f1 and wont rinse clothes so how can i reset it
washer fills but will not drain or spin!! should agitator spin seperatly from drum??? mine will not move!!
Jun 07, 2010 | Kenmore Oasis HE 27062 Top Load Washer
F1 mean on 110.2706
on oasis u have to replace the main board
Oct 04, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE OASIS
I jhavent got to figure out what an F1 is. I suspect its a "Fill" code 1?
Does it fill with water okay? If it dosnt fill within a cretian time I bet the computer see this and causes a F1? But Im guessing.
If it is this take your hoses off the washer not the faucet. put loose ends in the washer tub and hold em down while Turning on the water. Look for rust, sand or any thing that might be coming into the screens. If you have low water pressure this could be the cause also. But only remove the hose on the faucet end if you have low water pressure then look for the screens on the faucet end.
Also check the inlet of the washer at the water valve for mud, dirt or anything.
I need to know if this is what an F1 code is if you wouldn't mind posting back and if this helps you please rate me as high as you can. Thank you and good luck.
Oct 23, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Where did u get the part?
Cant remember which site, but just looked it up on google and shopped cheapest
Sep 08, 2008 | Kenmore Oasis HE 27062 Top Load Washer
F1 CODE COMES ON AFTER LID LOCK
THE PRINTED CIRCUIT BOARD IS BAD. I DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS MISTAKE COST $175.00. SO LIVE AND LEARN
Mar 30, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washer problems
Replace the computer yourself. takes 20 minutes very easy and part is about 150.00, I did mine.
Jun 10, 2006 | Kenmore Oasis HE 27062 Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
