Question about HP Photosmart C5180 All-In-One InkJet Printer
Have an error message oxc18a0401 what can i do? i replaced magenta ink cartrige an the printer went into the ink system failure mode and will not reset
    President:
  • 1,197 Answers
Do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then do a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in.
Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (have an error message oxc18a0401 what can i do? - c01424575.gif ).
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges ' message to display on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
  • if that doesnt help
    Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the unit off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate.
    if that doesnt work.....
    1- Turn off power and unplug from power source.
    2- Open right side of printer (looking at the front).
    3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
    4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
    5- Unplug power source.
    6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
    7- Plug in power source and turn printer on (Printer preparing occurred).
    you can also down load the following document for additoinal reference
    http://rapidshare.com/files/140957209/Assert__Ink_System_Failure_Actions_for_PhotoSmart_Six_Ink_Products.doc.html
    if that too doesnt work
    A- Press and hold the “left arrow” key.B. - Press the “Setup” key and release both keys.Display should say “Enter Special Key Combo”C. - Press and release the “OK” button.
    Display should say “Support” and display the FW rev (something like R0616R)
    Then perform the below steps:
    2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
    3. Press and release the “OK” button.
    4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
    5. Press and release the “OK” button.
    6. Display should say “Hardware failure status: Clear. Press OK to clear”.
    7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
    8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
    12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    at this time we have tried everything possible.... if it still doesnt work... there could be ahardware failure which requires Service from HP...
    Good luck
    Posted on Aug 09, 2010
      Brigadier General:
    • 3,917 Answers
    Hi
    Press and hold the "*" key. Press the "#" key and release both keys.
    Display should say "Enter Special Key Combo"
    Press and release in sequence the "1", "2" and "3" buttons.
    Display should say "Support" and display the FW rev (something like R0631R)
    Mine reads R0631M
    . Press and release the right arrow button until the display says "System Configuration Menu".
    Press and release the "OK" button.
    Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    Display should say "Hardware failure status: Clear. Press OK to clear".
    Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photo smart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
    Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    Please check this link for further help…
    http://www.inkbank.com.au/webcontent21.htm
    Let us know if you have something more to know else accept the suggestion.
    Thank You for contacting Fixya.com
    Posted on Jul 09, 2010
      President:
    • 3,278 Answers
    Hello.
    That error means an ink system failure.
    For your HP Photosmart C5180, from HP Support:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=1153481
    Hope this helps.
    Posted on Jul 08, 2010
    • HP Expert
    • 2,973 Answers
    Please un and reinstall the drivers of the device as per the link below.
    Installing Devices on PCs and Laptops
    • HP Master
    • 6,993 Answers
    to resolve the error message, you need to reset the printer. Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and the turn it back on.
    You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
    If that doesn't reset the printer, you can follow the reset procedure from the below hp link:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=th&lang=en&product=1153476
    Good Luck!
    • 542 Answers
    As per the error code and message you are getting and printer's age, this looks like a real error message.
    It signifies a hadware failure in the Ink System which is responsible for sending signals to the ink cartridge to print ink on paper.
    Some times its only a print head or carriage and most times its even the circuit board and other sensors involved that go bad.
    If in warranty, you should get it repaired for free by HP. In 90% cases they just replace the printer because repair is expensive.
    If not in warranty the repair will not be cost effective. But if you want you can call HP and take a quote.
    Even if you want to repair it yourself, you need to buy the complete Ink System from them which will be more expensive than buying new printer.
    Feel free to ask any question or concern you may have. I will be glad to help you
    Thank you for using Fixya.
    • Rajesh Pai
      Rajesh Pai Jul 09, 2010
      Please go through the below URL to resolve your problem.
      http://h10025.www1.hp.com/ewfrf/wc/docum...
    • Rajesh Pai
      Rajesh Pai Jul 22, 2010
      I didn't got any update from you? Hope your problem got resolved.
      Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    • 472 Answers
    There is one fix for the 0x errors and it doesn't always work but this is the only option.
    Press and hold the "*" key. Press the "#" key and release both keys. Display should say "Enter Special Key Combo" Press and release in sequence the "1", "2" and "3" buttons. Display should say "Support" and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says "System Configuration Menu". Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", Press and release the "OK" button. Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
    What do I do for a Oxc18a0401 failure
    Hello and Welcome!
    The error
    Oxc18a0401 is mostly occurred in HP printers
    To solve the error code
    Oxc18a0401,Follow the given steps
    • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
    • Remove the cartridges from the printer
    • Wait for the 'Insert Cartridges' message to display on the control panel
    • Disconnect the power from the back of the printer
    • Now wait 60 seconds
    • Now reconnect the power If the product does not automatically turn on, press the Power button
    • Reinsert the cartridges, and then close any open doors on the printer.
    • If you receive a prompt to print a calibration page.Print it
    • Reconnect the USB cable to the port of the printer & then try printing again
    Error will automatically remove.
    Sir, If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
    For further help, you can take my valuable,professional help by taking my Service
    Thank you for using FixYa!
    Dec 14, 2011 | HP Office Equipment & Supplies
    A ink system failure has occured oxc18a0401 i have cleaned the ink tips but no joy please help ta
    The 'ink system failure' error is caused by air in the ink feed tubes inside the printer. This problem is caused by either letting your ink run totally out in one or more cartridges or using poorly refilled cartridges. You will need to run a purge routine to flush the ink tubes of the air and clear the error message. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ that will walk you thru running the purge routine. It takes about 10 minutes to do but then your printer should be good as new.
    I hope this helps, if so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Apr 18, 2010 | HP Photosmart C6100 All-In-One Printer
    Ink system failure, won't reset, won't respond to cleaning
    The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
    I hope this helps, If so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Dec 31, 2009 | HP Photosmart C6180 All-In-One InkJet...
    The lt magenta and magenta just quit printing between pages
    1. Check if the cartriges are correctly installed:
    Installing the Ink Cartridges
    2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
    Color Mix or Missing Colors on the Diagnostic Page
    Repeat if needed.
    3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
    Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
    Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Ink system failure error Oxc18a0306
    Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
    Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Keeps saying to replace cartidge
    you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
    Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
    RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
    I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
    Mar 25, 2007 | Epson Stylus Photo RX500 Printer
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    73 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
