Question about Intel D946GZIS Motherboard
Hung PC Hello, I have recently noticed that my pC stops booting until it reches a stage where it displays some kind of sequence at the bootm right hand part of the screen. It stops at EB (wonder what it means). However it starts only after repeated attempts ( 10 or 15). Is my mother board or some part of it is dying.
  • captainrahul Apr 23, 2008
    Thanx for the guide and links.
    Been thru the manual
    Though it didnot help me much but it did give me some info on the codes EB. EB is mentioned at two places in the manual.
    port 80h post codes - EB means - calling DXE drivers- Legacy option ROMs.
    port 80h post sequence - EB means - calling Video BIOS.
    I donot understand the meaning of the above.
    All I know that a series of codes appear at the bottom right hand side of the screen when my PC boots. At times it gets stuck on EB (whatever that means).
    Can u help me in interpreting these codes, I am sure they must be meaning something.
    I have also noted that the fans in the computer also donot start when this happens.
    thanks in anticipation
    rahul
  • milopeer Oct 13, 2008
    I have EXACTLY the same problem. At first i thought it was my Primary HDD which coincidentally had a problem and got him replaced. But the problem still exists!
    President:
  • 2,351 Answers
I don't think so captainrahul,
Intel has some interisting suggestion for you to check on their web site. Click the link below & go over these checks. One could end up helping you cop a fix. Read through.
http://www.intel.com/support/motherboards/desktop/sb/CS-010254.htm
Next is the link to Intel for your board. (Drivers, Manual ECT).
http://www.intel.com/support/motherboards/desktop/d946gzis/is_manual.htm
Drop me a note if this has helped.
If this has not helped drop me a post & I'll go from there.
Luck!
Mike
Posted on Apr 21, 2008
  • Mike Peluso
    Mike Peluso Apr 21, 2008
    How to vote you're expert & also how to repost more questions for same problem or answer expert's questions.
    Enter FixYa.com site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Under the solution given by the expert, choose.
  • Mike Peluso
    Mike Peluso Apr 24, 2008
    rahul
    can you write down the series of codes that appear at the bottom right hand side of the screen when your pc boots & post them here?
    Is this a fresh/new build? Have you flashed your bios. Can you tell me what was the last thing you either installed before this error started?
    If I know what transpired before there was trouble & the series of code listed I can search my data base. If the screen goes by too fast try pressing the pause key on the keyboard to hault the screen.
    Mike
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Fitting an external PCI graphics card ... issues.
Go into the device manager find the card you do not want to use then disable it do not delete it. Restart the computer making sure that your display is plugged in you want to use and it should show up. The way your doing it is allowing both monitors to or both drivers are active. John
Apr 16, 2012 | Acer Veriton M420 PC Desktop
My Friend just received a cleaned T21 from her workplace. When I try to boot it up I get the following: Initializing MBA. Pres Ctrl+Alt+B to Configure... Managed PC Boot Agent (MBA) V 4.12 UNDI Initialize...
try clicking on this link and choosing Master Boot Record Repair.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-56102
Also, have you tried
Step 1. Make the DVD drive the first startup device in the startup sequence using
the following procedures:
a. Shut down the operating system and turn off your computer.
b. Press and hold the F1 key, and then turn on the computer. When the logo
screen is displayed or if you hear repeating beeps, release the F1 key. The
Setup Utility program opens.
Note:
If the Setup Utility program does not open, shut down the
computer, wait approximately five seconds, turn on the computer, and
then immediately press and release the F1 key repeatedly until the Setup
c. Use the left and right arrow keys to select Startup from the main menu.
From the Startup menu, select Startup Sequence and then press Enter.
d. From the Startup Sequence [Primary] menu, do one of the following to
select the DVD device that you want to use as the first boot device.
Note: When selecting your DVD device as the first boot device, be aware
that internal DVD drives are listed as IDE CD. If you will be using a
supported external DVD drive as the first boot device, select USB
CDROM in the steps below for your choice of DVD device.
v If your choice of DVD device is already listed as the first boot device,
continue with step 2.
v If your choice of DVD device is listed in the startup sequence as any
device other than the first device, select it and press the Plus (+) key
repeatedly until it is displayed as the first boot device. Continue with
step 2.
v If your choice of DVD device is listed as an excluded device, select it
and press the X key one time to add it to the startup sequence. Then,
select your choice of DVD device from the startup sequence and press
the Plus (+) key repeatedly until it is displayed as the first boot device.
Continue with step 2.
e. Press F10 to save and exit the Setup Utility. When the save and exit
message displays, select Yes and then press Enter.
Jul 18, 2010 | Lenovo ThinkPad T21 2647 Notebook
When switching on PC it does not boot up fully
Hi Craig
From what you are descrbing one of the background services is preventing start up from completing
Please try the following
1) Switch on PC
2) Continuoulsy press the F8 key until a start menu is presented, choose safe mode from this menu
3) Once safe mode has loaded up go to Start>Programs>Systems Tools>System Restore
4) From the system restore menu choose 'restore my computer to a earlier time'
5) From the calendar presented choose a date in bold when this fault wasnt happening and then click on next and follow the screen through
6) Let the system restore complete and it will automatically reboot and take you back to the mains windows screen
7) This should hopefully let the hung service be able to run
I hope this has been useful
Mar 10, 2010 | Dell Dimension 2300 PC Desktop
Enter bias to change boot sequence
Press F2 during the early stages of boot up (or when it says "Press F2 for setup).
You can then change boot sequence.
Mar 05, 2010 | Dell Inspiron B130 Notebook
I disabled video card now my monitor is black. i can see the boot screen. i can hear my desktop when it loads. i tried safemode(it never loads in safemode)...last known workig....i still cant see anything.
Kindly repair or reinstall your Operating system. It has a file that has been corrupted. To avoid the damage become big try to repair it or reinstall the OS without reformatting or erasing the files save in your hard disk.
Kindly follow the steps below:
To repair/Reinstall your operating:
1. Insert your CD installer into your DVD/CD Rom then reboot your computer/Laptop.
2. Press F8 or F12 to enable boot sequence and display it in order to select the boot. Then select the DVD/CD Rom boot. Or Press Del to enter CMOS and set the boot configuration sequence and select the DVD/CD Rom as your priority to boot the system.
3. *** soon as message will display "Press any key to boot CD" then press any key to boot CD. Then wait for the CD to load all its components.
4. After loading all its components kindly follow the instructions givien by the installation wizard. Note that if you where ask by the installation wizard to press r to repair or enter kindly select enter then let the system detect the existing installation of OS in your system then it detects then press enter then kindly select "Repair" to repair the detected OS or Select "Don't make changes and make it intact" then enter to reinstall the OS without erasing the files save in your hard drive.
5. Kindly follow the instructions given by the installation wizard to finished the installation or repair of your system OS.
6. If you don't want to repair/reinstall by your self then you can contact a technician expert in computer to fix it for you.
If you need more assistance kindly reply to this post.
thank you
geo_jonas
Jul 30, 2009 | Acer Aspire™ T180 PC Desktop
Boot hung up
The NIC is fine, however it hangs because it is searching the network for boot information. This NIC's boot timeout is a lot longer than most.
Sep 24, 2008 | Acer Aspire 5100 Notebook
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Boot sequence
<F10> (must be pressed when there is a blinking cursor displayed at top right of screen. Pressing <F10> once per second at this point will gain access.)
Dec 23, 2007 | Compaq Armada 1592DMT Notebook
Computer Boots but There is No Display
Make Sure wires of moniter is properly plug in , check specially VGA cable  and it can be because of RAM .
Gizmo1
Oct 14, 2007 | Dell INSPIRON 6000 CENTRINO...
Intel D946GZIS Motherboard Logo
117 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
