Question about Dishwashers
Indesit dishwasher DVG 622 K IX UK washes but does not rinse and dry.Powder door does not open .Items come out part cleaned even if the tablet is placed inside manualy , and still wet
5 Suggested Answers
  • 11 Answers
SOURCE: DISHES COVERED IN WHITE POWDER
To check on the source of the white powder (calcium?) soak some dishes in vinegar to see if this cleans them up nicely ... or if the 'white powder' is actually permanent etching. You may have very 'hard' water and will need to deal with that with a water softener or additives.
Read the following article for a better understanding and try the vinegar test . (also ensure you are using dishwasher specific salt to regenerate your integral softener... assuming you have one)
http://www.dishwasher-care.org.uk/best.html
Posted on Nov 02, 2007
  • 6 Answers
SOURCE: dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Posted on Mar 07, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
SOURCE: Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Posted on Jun 07, 2009
Dishwasher cloudy glasses
I do not have enough information to be able to answer with hundred percent certainty.
From my experience, the most common problem is the improper handling of the appliance. Driven by overwhelming commercials we often pass from detergent to tablets. The largest number of tablets contains rinse aid that we already have in the dispenser. Practical adding a double dose of rinse aid resulting in poor washing results and glasses look like washed in milk. The solution is to open the dispenser and put the dosage rinse aid to minimum. In electronic dishwashers new generation is even possible to completely exclude the dosage rinse aid if you are using tablets.
Dado
Aug 26, 2014 | Indesit Dishwashers
Detergent dispenser doesn't open
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
Apr 22, 2014 | Indesit Dishwashers
Dispenser door not opening, therefor tablet not being dispensed nor is rinse aid
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 04, 2011 | Indesit 23 in. DV62 IX Built-in Dishwasher
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Jun 26, 2011 | Indesit Dishwashers
Wash temp to cold dishes not clean even after #1 wash and detergent does not release either
I suspect the release on the detergent dispenser has failed, I am assuming that the water is heating up in the washing process, you can tell that by feeling the door during the wash cycle.
You have 2 options (if the water is heating)
1 replace the part
2 After it has done the first rinse and filled to do the main wash (or when it has filled to do the main wash without a rinse if you start without a rise) open the door and throw the powder/tablet/sachet into the dishwasher.and it will wash fine The only snag is you have to remember if you are doing a first rinse.If you throw the powder in too early it might drain out
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 02, 2011 | Dishwashers
Dishes not coming clean
Five common causes:-
1. The dishwasher hasn't got any salt in, or the salt dispenser control is set too low. Even if your tablets/powder have a salt function, it's often not enough in hard water areas and supplementary salt must be added to the salt dispenser.
2. There is no rinse aid in the machine or the dispenser control is set too low. Supplementary rinse aid may be needed even with tablets/powder which claim to include it.
3. The dishwasher is not reaching the correct operating temperature. This can be due to a faulty machine, or by using low temperature washes inappropriately. Low temperature washes are only suited to very lightly soiled loads which have not baked/dried on. There ARE special low temperature tablets/powders, but they're designed only for specialised domestic machines with low temperature overnight wash cycles or for commercial dishwashers.
4. The filters/debris traps at the bottom of the machine are not clean.
5. You're using the "wrong" brand tablets/powder. In this instance "wrong" simply means that your machine just doesn't get on with the brand you're currently using. price has little to do with it; I find with my current machine that the market leading expensive brand works poorly but the ultra-cheap supermarket basic value brand works perfectly. Also it can be down to using a genuinely wrong tablet/powder choice as per suggestion #3.
May 15, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit D63 dishwasher dishes not getting clean
check that the arms top and bottom turn freely and are not blocked.also if you use tablets,then you do not need to use rinse aid in the door,the coating could be due to over rinse aid as the tablets have this in,if these are ok you may benifit from putting a good quality cleaner through if
May 05, 2009 | Indesit 24 in. D63 Free-standing...
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
Owen Barnes
