Question about Panasonic CW-1406BU Air Conditioner
Water dripping inside
water start dripping inside the room after 7 years no problem work
  • 340 Answers
SOURCE: water dripping inside room
Unit needs to be slightly tilted to the out side. or drain pluged and dirty is the unit clean? to properly clean you have to pull take apart to clean
Posted on Jun 17, 2009
  • 233 Answers
SOURCE: Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
Posted on Jul 14, 2009
motor1258
  • 6674 Answers
SOURCE: My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Posted on Jul 29, 2009
  • 202 Answers
SOURCE: water dripping from air condtioner-inside room
your evaporator might be dirty needs service or the drain pipe is clogged
Posted on Aug 01, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: the ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
Posted on May 27, 2010
AFTRON Portable Air-Conditioner AFPAC1200H using lots of water but not dripping or leaking - where is it going?
Your question is a little confusing. You could mean takes on water in a tank inside the machine, a bucket you empty when it fills. Sounds like it is dehumidfing because that is what they do, take water out of the air, and just blow room temperature air out, not cold. Many portables have that feature.
If that sounds like it, find the Cool button, or mode button to switch to the cool function.
Jun 09, 2016 | Filter Heating & Cooling
Rusty water dripping on the inside of the door after rinse cycle
Pull the screws out of the door check to see if they are rusted run the machine the outer door panel off should be easier to find the leak
Mar 30, 2014 | KitchenAid Dishwashers
Our air conditioner9 which is only about 2 years old) just pours out water. It soaked the bed which was next to it.
Go outside where the air conditioner is. You will find several holes on the bottom of the unit. Clean the hole out and you should see water start dripping out of at least one of the holes
May 30, 2011 | Kenmore Single Room Air Conditioner
The ac is dripping inside the room
Hello.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
Why is water dripping from the overflow quickly
accumulating water is as you assumed - the air conditioner is taking the humidity from the space and the water is nothing other than condensation. I would not worry about it at all.
You need to start worrying if the unit 'doesn't' produce water.
May 14, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Jul 13, 2009 | Goldstar WG5000 Air Conditioner
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
Air condition cleaning
hi! there,
if your unit is almost five years from now,its more convenient to have a maintenance schedule every two to three time a year,if this a windows type,cleaning of ac unit mostly the eveporator and condenser should free from dust,upon installing,the a/c unit should be eleveted down on condenser,the tray should have a drain with hose to drip the water outside your room,so that water will not leak on your light,see this may cause electrical fault resulted on burning.have always clean the filter.try to inform the maintenance crew to elevate the condenser portion down gradually so that water will drip outside the room.have anice day,don't forget get to rate me,and thank's a lot.
Apr 26, 2009 | Heating & Cooling
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Room air conditioner
the unit needs to be tipped outward so that the lowest point of the unit is actually outside the window.
Jun 03, 2007 | Goldstar R8000 Air Conditioner
Panasonic CW-1406BU Air Conditioner Logo
138 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
