Question about Kenmore Elite Oasis 27052 Top Load Washer
Whenever we load clothes in and start it, it'll beep and say F1 on the screen?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Basic Reset
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
Feb 26, 2014 | Frigidaire Washing Machines
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
How to fix my Whirlpool Cabrio washing machine F1 code that keeps popping up whenever I turn on the washing machine.
Hello, error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray.
Thanks
Jun 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My acer wont load when i first turn on, or load,gives 2 loud beep
Sounds like the hard drive is going bad. Take out the hard drive and see if the laptop behaves like that if it doesn't then you know the hard drive is bad. If it still does then it could be a motherboard problem.. With it making those beeping noises when you first turn it on, they keyboard could be going bad because that would make a laptop start beeping like that as well.
May 19, 2010 | Acer Aspire 5100 Notebook
Machine continues to display F1 and other F displays. Moved clothes around and pushed power which started machine again, but interupted again shortly afterwards with beeping.
There is a recall on this washer.
Please call Whirlpool...800-253-1301
There is a recall on the Cabrio Whirlpool washer for the F1 code.
The problem is the main computer brain - it is a common defect that whirlpool likes to keep quiet.
Hope this is helpful for you. There is, unfortunately, no end-user fix.
Thanks for using FixYa - a FixYa rating is appreciated for the time taken to answer your FREE question.
Mar 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Press f4 to resume
u need to go into bios setup.this can be done by pressing del button on ur keybadr while booting is goin on. some time the key to be pressed will be F10 or F1 instead of del key.
There will be an option as stop booting on error. disabl;e that..n it ll be fine.. btw to find out the error u'l have to specyfy each n every settings in ur bios.So its better u to ask for a person who knows these things to ur home.. Else u can do by exploruing these things urself.It ll be fun..i would prefer this..
Feb 12, 2009 | HP Pavilion dv2000t Notebook
Oven can not heat
f1 is the code for a faulty oven control or as you know it the clock replace it
Feb 12, 2009 | Kenmore 96532 / 96534 / 96539 Electric...
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Kenmore Elite Oasis 27052 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
