I have a Hoffwel Air Con but dont know how to get the thing to give out hot air as i have no instructions
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
SOURCE: Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Posted on Jun 23, 2008
jumptrout51
  • 3361 Answers
SOURCE: air not going cold its staying hot
Set the thermostat to COOl and lower the temperature control.
Posted on Mar 10, 2009
  • 659 Answers
SOURCE: need instruction manual for mistral mpac140
They do not have a downloadable manual that I could find but I have included their contact info so you can contact them directly. They may be able to get you the info you are requesting.
http://www.mistral.com.au/contact_us/contact_us.asp
Posted on Apr 02, 2009
  • 47 Answers
SOURCE: air con just blows hot air s type jag
With the key in the off position; remove the RDO BAT fuse for at least 10 seconds then replace the fuse; turn on or start the vehicle and try the A/C again. Removing the fuse should reset blend actuators
Posted on Apr 24, 2009
Hoffwel Air Con Remote
I have found 1/2 the time there is some type of liquid that has gotten inside the remote and not dried but become a film that will make connections as described, corrosion on the contacts and battery also will cause this on the boards,wipe the board down with acetone, otherwise its damaged and needs replacement.
Jun 28, 2013 | Heating & Cooling
Air Con on my 2009 Mercury grand marquis is giving me problems. Cold air blows out the defrost vents but will not blow out the main vents. Please advise
the blend door in the lwr air vents is stuck it should be down by the squerrl cage also it could be electronically controlled
Jul 14, 2012 | Cars & Trucks
I have a hoffwel Air conditioniner and the remote is broken Hoffwel went out of business years ago where can I get another remote that will operate it Thank you
Welcome to no spares, I have tried for over a year to get a remote but none around so atended autions till l found one that worked with air con and barted for it as a/c didnt work but alas that control packed up.
All is not lost, local a/c man can get a multi manufactor one and "tune" it in for you at a price...l was quoted $180. So try your local A/c man.
Aug 28, 2011 | Heating & Cooling
Air con stuck on, temp gets very hot
have you looked at the switch,
try this first then check power to air con pump
Mar 02, 2010 | 1999 Jeep Grand Cherokee
English instructions for gree aircon y502k
Hello there in China!! I am sorry you are freezing you're **** off, LoL. Not funny I know. I can't find nothing in English for the name you gave me. I would think that whom ever runs this Hotel would be of service to you as you are a guest there and a paying customer there. I do not know there customs however . Depending how long you will be in this hotel, I would try to find someone there that would be able to translate these buttons for you, even if you offer a small amount of currency to help you. You shouldn't have to go through this!! They should have a maintenance person there to help with these problems, so contact the front desk. I hope this leads you in the right direction, I would not put up with this! You are a guest.
Sincerely,
Shastalaker7
Dec 20, 2009 | Heating & Cooling
Air Con E12HKE which is not giving any Hot air.
check to see if the wiring harnes has not come loose from the heating element. Check the heating element itself to insure that it is in good shape. To actually test a heating coil you will need an electrical meter one that has an ohm setting. Place the setting to "ohm" and disconnect the wiring from one side of the heater coil marking them to insure they go back the same way. Now take the meter connect one probe to the end of the element and the other probe to the other end of the element. If the meter gives you a signal that means you coil is good so the last thing to check would be your high limit switch. This switch turns off the heater in the event it gets too hot. They are usually preset at the factory for a specific temp. If the high limit switch has burned out heater won't work either. This switch looks like a silver button and has 2 wires going to it. Easy to remove and replace and inexpensive to buy Take model and serial numbers to appliance supply for the correct parts for you unit. Good Luck
Dave
Jul 23, 2009 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
