Trying to install a new hard drive in a cf51 laptop and I'm getting "no operating system found"
    Guru:
  • 1,342 Answers
A new hard drive will not contain an operating system. It will have to be formatted and then an operating system installed. Follow the instructions that came with it or try booting with the operating system CD.
If this information was helpful please vote.
Thank You
Posted on Apr 19, 2008
When I tried to open my samsung N150p it says that "Operating System not found" and then when I tried to look for the "SATA Port1" it says "none", how can I fix it?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Mar 06, 2013 | Computers & Internet
No operating system found on a gateway solo 9300 laptop
if the hard drive has been completely erased then you will need to boot from a windows disc and re-install windows on it.
Jan 08, 2013 | Gateway Solo Pro 9300 series
When i boot up my laptop i am getting the error message, "operating system not found." Can you please give me advice on what to do to fix my laptop? Toshiba laptop and im scared i may lose the things
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 30, 2012 | Toshiba Computers & Internet
My Sony Vaio Laptop (Model VPCEE42FX) isnt working, it turns on, but then it says "Operating System Not Found." Can you help me ?
The laptop cannot find the Operating system which is installed on your hard disk drive. Go into the BIOS (setup menu) and see if the hard disk drive is present. If it is then your might need to reload the OS ( operating system software,i.e. Winodws Vista, Windows 7 ). If the BIOS does not detect your hard drive then either your hard drive is defective or the motherboard has a problem.
Jul 26, 2011 | Sony VAIO VPCEE42FX/WI 15.5" Laptop PC...
My hp desk tip says " Disk boot failure insert system disk and press enter" Please help what to do.
Your hard drive may be faulty, this is why the Windows operating system not found.
Go into the BIOS and see if the hard drive is detected, if not reseat the hard drive and boot up again.
If the Windows operating system not found then most likely the hard drive is faulty and to get the Notebook working again, replace the hard drive, install Windows on the new hard drive plus the HP desktop device drivers and your programs.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Jul 14, 2011 | Computers & Internet
Operating system not found , cos i took the hard drive cos after i tropped my laptop it starts to make noise and it wont start it tries to solve the problem but then it says windows cannot solve the...
Since the noise is associated with the hard drive and the system was dropped, then most likely you will need a new hard drive.
You can get a new drive at www.newegg.com among other places then once installed, boot to you Operating System disc and reinstall the OS
Jun 19, 2011 | Computers & Internet
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
Dec 18, 2010 | HP Pavilion dv6000z Notebook
T 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Oct 26, 2009 | IBM ThinkPad T43 Notebook
Get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
Apr 09, 2009 | Sony VAIO VGN-FJ270/B Notebook
Computers & Internet Logo
David Payne
David Payne
